mandrel vs crush bending?
Old Nov 5, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
ok i know this is sort of a nub question but how do you identify mandrel bending from crush bending?
i work at a parts shop, and we have oe replacement pipes, but where it bends there is sort of a wavy section almost like its overlapping on the inside corner, but other pipes have bends and its not a completely consistant diameter, it doesnt look like it overlaps but is slightly narrower than the straight sections
are they both crush bent?
Old Nov 5, 2003
skipbarber's Avatar
you pretty much got it, from my understanding, mandrel bent pipe typically is made by using a pulley type wheel and a lever. as you pass the tube through the pulley you pull the lever down to whichever degree you want the bend. this keeps the diameter consistent throught the bend in the pipe. im not familiar with the process for crush bends but it does have creases on each bend.
Old Nov 5, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
the creases in crush bending often fold toward the inside of the pipe, thus restricting air flow.
Old Nov 5, 2003
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
Righto... Like they said, Mandrel bends are a consistant diameter thru the bend, with no internal or external compression ripples. Crush bends create a ripple on the inside of the bend. There are shops who do a high quality crush bend using a filler to keep the diameter as consistant as possible but ultimately Mandrel is your best bet for a quality bend.
Old Nov 5, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
mandrel bent piping looks like the metal is streatched
Old Nov 5, 2003
phatcyclist's Avatar
phatcyclist is an unknown quantity at this point
there are 3 types of pipe bends...
1.crush bending with the ripples that sucks
2.compresion bent tubes have a smoothe transition,but the pipe still gets smaller through curves
3.mandrel bent, there is NO loss in diameter through bends, but you cant get it done at a machine shop, it has to be manufactured a certain way.
Old Nov 5, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
phatcyclist, you can go to any descent muffler shop and get a good custom madrel bent exhaust. It does not have to be manufactured. It is all about the machine you use to bend the piping. Mandrel benders are more expensive than crush benders. I got custom cat back 2 1/4 stainless mandrel bent for 200.00
You could mandrel bend yourself if you had the machine to do it...
Old Nov 5, 2003
nspice's Avatar
nspice is an unknown quantity at this point
actually i do belive the way they do mandrel bent is they heat the metal and shape it the way they want it, thus keep the diameter consistent.
Old Nov 5, 2003
IronFist's Avatar
Pff. Just run open headers.
Old Nov 5, 2003
cdmx's Avatar
i have crush bent....mabye i have mandrel bent?? they put it through a roller thing and bent it while it went through.
Old Nov 6, 2003
HondaLuver's Avatar
Its a celebration bitches!
my mendrel bent piping is soo nice and smooth, i just wanna jizz all over it.
Old Nov 6, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i just had a section of my tanabe srm cut off and custom piped to go around the progress rear sway bar, but that section is crush bent...the job was done in a rushy manner, so the pipe is really deformed, but it does the job, and doesn't bang on the swaybar. Is that bad? Will that section of the pipe affect performance? Can i take it somewhere to have them mandrel bend that section so it looks better? ^_^
Hondaluver: where'd u get urs done? and how much?
Thanks
Old Nov 6, 2003
HondaLuver's Avatar
i got mine done in woodland hills, its called LaBree motor sports 818-704-7950, he knows his ****
Old Nov 6, 2003
§C§H§O§C§O§B§O
cost? i paid 60 for an ok job
Old Nov 6, 2003
HondaLuver's Avatar
for the whole thing, umm, its like a fixed rate for the pipe, then each bend, then the welds.
Old Nov 6, 2003
HondaLuver's Avatar
probly no more than 200
powman02
Sep 15, 2015 07:38 PM
MamaBear2015
Sep 4, 2015 09:04 PM
SidCivic
17
Aug 23, 2015 03:14 AM
brainwashedmc
Jul 27, 2015 10:05 PM
Q-Bert
Jul 19, 2015 09:09 PM
