Oil filter issue
Old Nov 3, 2003
ncwcivic's Avatar
ncwcivic is an unknown quantity at this point
Question Oil filter issue
During my recent oil change everything went fine, until i removed the oil filter and noticed it was dry inside. As natural i freaked out and thought my car was broken. It has been driving fine and has had no abnormal noise comin from under the hood.
So i bunched a hole in the filter and all the oil came spilling out so i assume that it was just clogged.
So my question is, should i be concerned about my car or just assume that it was a defective filter?????
thanks for your help
Old Nov 3, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
How long was your car sitting?
Old Nov 3, 2003
civic01vtec's Avatar
i never heard of such a thing....but yeah, maybe it was sitting too long. You are suppose to run ur car up until it hits normal running temperature b4 u drain ur oil.
Old Nov 3, 2003
ncwcivic's Avatar
it was driven for 1/2 hour then allowed to sit for about 1 hr still real warm then drained
Old Nov 4, 2003
flotsamm's Avatar
Dry? The filter sits at an angle, so when you take it off it wont be totally full. If it was clogged you wouldnt have any oil circulating and your engine would run sieze up I would think. Unless there is some oil filter bypass..
Old Nov 4, 2003
BucketHead's Avatar
BucketHead is an unknown quantity at this point
the better oil filters are equipped with an anti-drain valve to prevent having to siphon oil into the filter on start-up...A GOOD THING!
Unleaded
Jun 26, 2007 09:25 PM
silverdevil
Feb 2, 2002 08:54 PM
Grey
16
Jan 27, 2002 11:34 PM
02Si
Bolt-on Engine Performance
Jan 7, 2002 11:35 PM
02Si
Jan 6, 2002 09:18 PM
