Removing interior
Removing interior
Can anyone tell me how to remove the interior. I did a search and I can find a peice here or another there, but not an entire list. I want to take seats (front and back), console, door peices, erverything. Please help!
man taking out the fronts seats are easy....just unbolt the bolts from the bracket and disconnect the SRS plug....and also taking apart the console and door pieces has been discussed to...so what you might have to do is copy and paste and print all the information seperate.... I haven't seen anyone create a FULL INTERIOR REMOVAL DIY but myabe look up grey cause he gots a **** load of DIY's
to remove all of the back you have to pull down the 40% seat, unscrew two bolts and slide it out. The other seat you will have to remove 1 bolt and slide it out. The bottom seats are only held in by one bolt. To remove the side plastic rear panels tere are screws where the handle bars are, take those out. Also you will have to disconnect the seat belt bracket at the bottom. Pull off the gray c pillar covers. Then pull the handle of the rear plastic arm rests and they should pop out. The rear deck is held in by plastic connectors and little tabs. make sure the rear 3rd brake light is disconnected.
I need TP for my bunghole
got here and look at the diagrams
http://www.hondaautomotiveparts.com/...catdisplay.jsp
ballmich
Jul 9, 2015 11:59 AM
