Car Service...
Old Oct 29, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
Car Service...
Since I got my car I did all the service on it myself (except for the first oil change) I have the car at about 20,000 miles and I have since switch to Royal Purple Synthetic Oil :-) Anyways.... What exactly does Honda do when they service our cars... I would like to make sure I am not missing anything - I check all my fluids and change my oil check the brakes and tires - even checked the plugs once outta bordum. What else should I check?
Old Oct 29, 2003
robbclark1's Avatar
Retired suspension supermod.
oil your door hinges, look at your air filter in the glove box...hmmm
Old Oct 29, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
I heard some dealers change the fuel filter like around 30K miles. Lube and grease fittings. I know they grease the control arms.
Old Oct 29, 2003
obtix's Avatar
What kind of grease should I use?
Old Oct 29, 2003
Bogus1's Avatar
Which part of your car. When I got mine done I went to local auto shop. They got like this compressor filled with grease. He hooked it up to my fitting somewhere by the controll arm, just like 2 seconds he was done.
As far as hinges; regular grease, what ever you got. Lithium grease (the white one) should be OK, or just WD40.
Old Oct 29, 2003
obtix's Avatar
alright, next time I change my oil i'll do that - as long as I am not missing anything on my motor ;-)
Old Oct 29, 2003
jenjens_civic's Avatar
jenjens_civic is an unknown quantity at this point
heh, dont forget to put the sticker, telling you when your next oil change is
Old Oct 29, 2003
obtix's Avatar
haha cant forget that
Old Oct 29, 2003
skipbarber's Avatar
if you live in moist regions, the manual says you should lift your car and spray off the bottom of your car. i got the rubber under coating to avoid having to do that. other than that, just follow the maintenance schedule in the manual ontop of everyones suggestions
Tedverseti
Apr 23, 2020 01:45 PM
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
