- Can Someone Explain Gear Ratios?
- Leather seats how to???
- custom 5spd shift gate?!?!
- LX engine swap
- General Spoiler Info
- Ok to run steel wheels without hub caps?
- Voltmeter???
- Any Danger of Leaving a CAI on over the winter!
- Can i put synthetic motor oil in my manual tranny?
- HELP!
- Stock Tire + Rim lbs.
- exhaust is knocking anyone got any ideas??
- De-badging my EX coupe.. use dental floss?
- Install sidemarkers? Watch out for rust!
- Custom Header.....
- Help VAFC need help setting
- Cat location....
- Painting Front Lip
- accord leather seats
- oil pressure guage edit* attn honda techs
- Deep Tone Muffler
- What kind of silicone to reseal headlights?
- Silicone to reseal cleared headlights? don't need it.
- a/f gauge diagram?
- Nasty Rattles
- Lower Grill removal
- New 03 Civic
- Question reguarding nitrous and turbo???
- Need some advice on winter storage...
- Flat Smoked Tail Lights, help!
- New car, how long till i can get on it
- 2k3 Civic HX/DX no longer get anti-sway bars...
- 2002 center dash console panel removal
- Transmission out on 2k1 at 25,000
- AEM/Injen CAI vs. K&N FIPK
- ·&%/)% pot holes!!
- Auto Down Passenger Window
- Fixing the rattle
- INJEN CAI or K&N FIPK?
- SRS
- Stock Shock Diagram anyone?
- Resonator?
- <az> something funny
- 3 point double release safety harness...
- Grinding Sound Near Front Passenger Tire
- ENGINE SWAP WIT H RSX TYPE-S MOTOR??
- Best spot to ground indiglo gauges?
- Where is the best place to let the car during the winter?
- CAI Intakes
- jack spot
- altezza grill
- Acura 1.7 EL backend conversion on civic sedan
- 20 K Service??
- where is o2 sensor?
- How to take Vinyle Decal out?
- Can anyone answer these two questions quick.
- air/fuel guage question
- Power/Rate Ratio....
- 03 Center Console (more responses the better)
- New dashboard lights on 2003 into a 2002?
- BOLT ON HP GAINS
- Heatshield
- Intake Brands, Which is better?
- CENTER CONSOLE SWAP FROM DX TO EX 03"
- how to get the silencer out of N1 exhaust
- removed intake resonator
- apexi v-afc or s-afc placement
- best way to fix fogged out projector lights
- just removed my a/c
- Help with mounting/changing tires
- how to install air/fuel guage??
- installed Konis for rear on Sedan need help.
- This is why you need a rear camber kit
- NEW TRUNK!!!!?!?!?!?
- Valve Cover HELP
- Reverse Indiglo Gauge question?
- WHY CANNOT WE TURBO CHRAGE OR SUPERCHRAGE??
- DIY KAMINARI BODY KIT
- what are the dimensions our trunk
- Does anyone know where i can get ex gauge cluster?
- I there a DIY for rear camber
- Help with removing trim piece
- DC TCS not center
- SRS light---> Searched respond ASAP pls!!
- can i replace the 2door side mirror with the 4 door mirror?
- injen cai install
- What could be wrong
- Headlight Aim
- help help help, someone broke in my car
- Parking Break Porb......
- anyone know how2 add a tube to shoot water from the back of the car?!?!
- installing NOS questions
- Cleaning Your Engine
- leaking apc tails
- awkward question...please help
- How to jack up rear side of car?
- Need Help w/ DC TCS Exhaust
- Air/Fuel Ratio Gauge Install help PLZ
- M3 Mirrors w/turn signals
- help wiring the angel eyes halo
- Field Hyper R on LX Coupe
- Sneaky Pete (nitrous system)*opinions*
- wats some of the things i need after i install aftermarket springs?
- removing rivets from door for power window motor
- headlight question.....
- Piggyback on the OBDIII
- Injectors for hondas
- Removing Rear Bumper...How do I do it
- What all is involved in installing a Carbon Fiber hood?
- How to install neuspeed upper front strut
- Squeeling Noise, HELP...
- 5 speed fluid change
- engine manegement system
- OEM headlight MELTED
- Trunk Popper Installed! (edit:PICS)
- Headlight wireharness
- Best Car Cover for the winter
- ABS LIGHT ON AFTER CHANGING CLUSTER
- Rotten eggs, smelly smelly. Any suggestions?
- Reground cam shaft from crower
- mounting factory spoiler?
- Cherry Bomb
- Anyone ever installed 6" Hi power lights?
- DIY: Spark Plug Installation (part II /w tips)
- Type R steering wheel???
- glasspack-resonator???
- Duble pumpin
- UNDERDRIVE PULLEY?
- ALL MOTOR???
- Storing car for winter what should I do
- DropZone Coilovers
- Big Problem plz help
- REALLY REALLY BAD PROBLEM HELP !
- Headlight Brackets ( Am I missing Screws)
- question about resonator???
- How to fix "DING" on door?
- DIY!! AC power for your civic ooOooOOooo
- DIY In-Dash Tach for DX?
- DIY : Install EX door handle on LX
- Question about the stock gauges
- vtec head for sale?
- H1 bulb into H3 slot?
- Apex Update for V-Afc
- AFTERMARKET steering wheel??
- FACTORY RIDE HEIGHT???????????
- How Does VTEC Work?
- Broken retaining pin in wheel win.
- Questions Regarding the Steering Wheel
- how do i....
- Will this hurt my engine...
- Door Handles
- i have 2.25" pipe and i wanna change it...
- remote start for civic?
- timing on car mess up?
- Skunk2 Front Strut bar?
- TYPE R UPPER FRONT
- throttle body spacer
- Intake Question
- clutch / tranny problem
- how different are the coupe fenders then the sedan fenders
- How many beeps do u here when u turn d ignition on???
- I NEED HELP BAD!!!!!
- How is a warrenty Voided
- PIAA Wiper Blades
- exhuast goose chase
- Injen heat shield
- getting oil changes at honda dealer
- oil filter wrench
- ex cai on an lx?
- Installing an o2 simulator on a testpipe?
- What does this mean?????
- Doing a oil change for the first time...
- Block Heater?
- Odd question about wheels....
- Smoked Tail Lights - Clear Coat???
- diy si headlights?
- Header Torque
- RSX Sway Bar DIY
- Rotating Wheels....Torque
- Installing ingiglo emblems
- just installed cam gear
- AEM CAI filter cleaning
- Help with catback.
- should i get a camber kit? (alignment form pic)
- Windshield wiper delay?
- Aem bypass valve question
- Engine drop....
- engine swap
- port and polish?!?
- dash cluster swap from dz to ex
- Pullies
- custom box help in the DIY secton on
- So is it bad to get the first oil change @ 6500 miles?
- Rattle sound when accelerating
- removing carpet in trunk
- Removing engine mount for HP Header
- what happened to my valvecover DIY...it doesnt work
- Don't know where to post this...anyway ... it is some tech stuff... =)
- much faster
- E Brake Aluminum Handle from eBay, How to Install?
- ecu's
- clear headlamps and intake intsall
- Removing carpet in trunk
- Turbo? Does this really work?
- The torque on Upper Front Strut bar?
- Need tech help..
- for those with the evo. how loud is the greddy evo???
- Need help with my HP header
- Custom sub box help
- Someone help me out please... So confused...
- 14,000 miles now what??
- Question for front brakes.
- Question about interior paints/dyes
- Need help with exhaust work...removing custom cat back...
- help got big problems
- Should I use 5w20 or 5w30 oil?
- PIAA fogs no longer working, anyone know? Blown fuse?!
- Oil Change Question
- Quick answer if you dont mind.
- "Drain Pipe"
- turbo/Header
- can factory tail lights be openned??
- Shift Knob Installation
- How much drop with Koni yellows????
- o2 wires.....
- crank pully help??
- Pillar mount pods for 02 civic's?
- putting in a rear strut tower bar for 4dr EX
- pin stripes
- Removing kick panel?
- RSX parts in the Civic???
- Spoon Sports radiator cap
- honda brake fluid or other brand dot3?
- PASSWORD FOR our cars
- Lower dash removal.
- 2003 Civic Fuel System
- engine question
- engine paint
- easy upgrade
- [ Turbo and Intake ?? ]
- on fender rolling....
- Speedo Clear Plastic Guard...
- trim pieces
- launching a manual
- accord keyless entry???
- Winter question ...CANADA TEMPERATURE
- HELP ME!!!
- *Edited* My experiances w/ removing/installing cat back exhaust
- www.jdmhondaparts.com
- Altezza Grill for 2drs
