Lower dash removal.
I sure wish my car was newer
Lower dash removal.
I have a 2002 EX coupe and I want to do a little project that involves removing a lower part of the dash. There's a little part with the cigarette lighter thing, and its just a plasic rectangle. I want to replace this piece (and lose the lighter coz I never use a radar detector or a lighter) with carbon fiber. How do I go about removing this piece? I know there are threads talking about removing the entire dash, but I need to know if there is cutting required and all of that. Thanks.
p.s. - if this is covered in one of those other threads please link me to it coz I must've missed it.
i went with CRUTCHFIELD's method...which was just to pry it out...all i did was stick my fingers in between the trimpanel that you wanted to remove and the center console and just yanked a lil bit from the bottom. its held on with 6 clips i believe
Quote
[hr]Originally posted by: STang57
i went with CRUTCHFIELD's method...which was just to pry it out...all i did was stick my fingers in between the trimpanel that you wanted to remove and the center console and just yanked a lil bit from the bottom. its held on with 6 clips i believe[hr]
-DavidCPA
Ok, not that I know how to remove the entire piece, I need to know if the part with the cigarette lighter is a seperate piece pushed in from behind or if its one continuous piece of plastic. The fifth picture shows the place I'm talking about. Also, what, if anything, is behind it?
JetsterDajet
Aug 16, 2015 01:56 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
fafa1234
Aug 8, 2015 06:42 PM
