Rotating Wheels....Torque
Old Oct 19, 2002
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
I just rotated my wheels yesterday by myself and I was wondering if I torqued the nuts enough/too much. I did not have any special torque wrenches or anything, just the good ole' Honda tire Iron....
I weigh about 140lbs and I was putting alot of my weight on each lug nut until it wouldn't go anymore? Good/bad? anyway I was driving around on the highway and didn't feel anything weird, I'm just worried about any potential problems because I did not have the lug nuts properly torque to factory specs.
Thanks
Old Oct 19, 2002
mohawkboom's Avatar
Bad...you may be stretching the threads in your lug nuts. your only supposed to torque them to 40ft.lbs..
Old Oct 19, 2002
Taffy's Avatar
Oh no.....What do I do?
Just let it be or do them over again?
Old Oct 19, 2002
Travii's Avatar
Travii is an unknown quantity at this point
You can take your car to a discount tire co near your house, they might do it for free if you catch them on a day they aren't busy I would try wed. They will probably charge you but you can have them rebalance, rotate, and tighten the lugs right for you.... Thats what I would do.
Old Oct 19, 2002
CivicSouldjaEX's Avatar
I work at discount tire co. we torque all hondas and acuras at 80ft./lbs, like specs and I think you overtorqued it, so you might not hear anything wrong with it but later on it will warp your disc.
Old Oct 19, 2002
VNlilMAN's Avatar
The Standard One
i just step on the iron till i hear a noise
Old Oct 19, 2002
BlkVeloz's Avatar
BlkVeloz is an unknown quantity at this point
Man, just spend the $$ on a torque wrench and you'll never have to worry about it again .
Old Oct 20, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
Quote
[hr]Originally posted by: BlkVeloz
Man, just spend the $$ on a torque wrench and you'll never have to worry about it again .[hr]
are torque wrenches expensive?
Old Oct 20, 2002
mohawkboom's Avatar
Honda's 80?.. you nuts [IMG]i/expressions/face-icon-small-smile.gif[/IMG]...I was a tire installer for quite a few years.. the only cars above 40-50 are Vipers, vette's, and some exotic cars...
Really it's not much to worry about..most shops..even delaes just use an impact wrench and tighten it fairly well.. they never check to torque the nuts properly...
If you went insane on it thouhg it's a bad thing...it can cause your disc to warp and even crack..
Old Oct 20, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
the manual even says 80ft-lb for our cars...my friends cavalier z24 is 100ft-lb
Old Oct 20, 2002
VNlilMAN's Avatar
The Standard One
ya i dont think its too important, i always see them cranking the impact wrench. i KNOW its not 80lbs cause i have to jump on the iron like 3 times to get it loose. 80lbs, i could almost loosen it by hand.
Old Oct 20, 2002
angjc3's Avatar
angjc3 is an unknown quantity at this point
hey..since we're on the topic of torque
it's supposed to be 80 lbs for our tires
and I installed a upper front strutt bar and a lower rear tie bar
those are supposed to be at 40 lbs of torque
I didnt use a torque wrench and I just tighted them as much as I could
is that bad???
could I warp my suspension?? or something like that?
[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 20, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: 4drcivic2k1
the manual even says 80ft-lb for our cars...my friends cavalier z24 is 100ft-lb[hr]
I knew I shouldn't have taken those paper candies with superman on them back in highschool..lol
Old Oct 20, 2002
VNlilMAN's Avatar
The Standard One
lol, you had superman on them, i had naked chicks on mine [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Oct 20, 2002
Quote
[hr]Originally posted by: VNlilMAN
ya i dont think its too important, i always see them cranking the impact wrench. i KNOW its not 80lbs cause i have to jump on the iron like 3 times to get it loose. 80lbs, i could almost loosen it by hand.[hr]
hahahahahaha good luck trying to loosen it by hand... can you unscrew an oil drain plug by hand? didnt think so...and those are only 12ft-lb.
Old Oct 20, 2002
VNlilMAN's Avatar
The Standard One
my badd, i meant by hand as in turning the iron by hand instead of stepping on it as i normally do... and i said 'almost' cause i still need to kick it slightly in order to loosen it by hand(again, using the iron)
Old Oct 20, 2002
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Vnil, your car looks like it has a huge wing on it from the sign behind your car in your sig. pic [IMG]i/expressions/face-icon-small-smile.gif[/IMG].
Matt
Old Oct 21, 2002
Taffy's Avatar
I just bought my torque wrench it's so cool! Sears Baby!!!! It was like 24.99 and the 19mm socket was like 6.99, so I suggest you go and pick one of these up cause it's definately a good investment[IMG]i/expressions/face-icon-small-smile.gif[/IMG] So I guess tommorow I'm gonna go bust my nuts and torque them up properly[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Oh yeah if anybody wants their wheels torqued properly I'd be more than hqappy to do it for ya, as long as your within 5 miles of my house!
Old Oct 21, 2002
VNlilMAN's Avatar
The Standard One
ya, i was thinking that... if i'm bored or something i'll photoshop it out. the focus on the camera sucks too cause the front is much bigger then the rear even if the front was closer to the camera.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
ThatGuy913
Sep 28, 2015 05:35 PM
redcloud
Sep 7, 2015 01:45 PM
rainman15
Sep 6, 2015 11:10 AM
