should i get a camber kit? (alignment form pic)
Old Oct 19, 2002
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
Should I get a camber kit for my rears?.. is it odd that the right-rear would be more off than the left-rear?.. I had the eibach pro-kit just put on.. do i have nothing to worry about as long as i rotate regularly? any opinions welcomed...
[IMG]i/expressions/face-icon-small-puke.gif[/IMG]
thanx![IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Oct 19, 2002
VNlilMAN's Avatar
The Standard One
only thing not within spec is the rear right, do you have a camber kit? where did you get that sheet anyways? was it free?
Old Oct 19, 2002
I don't have a camber kit,.. that sheet came with my alignment that i had done at "town fair tire" its a local tire/wheel chain in the MA,NH, area..
Old Oct 19, 2002
oh yeah the 4-wheel alignment was $60..
Old Oct 19, 2002
Gryphin's Avatar
00 Hatchback Owner
would weight get your angles off? got any subs?
Old Oct 19, 2002
Quote
[hr]Originally posted by: Gryphin
would weight get your angles off? got any subs?[hr]
I doubt it,.. my sub & amps are all pretty much centered in my trunk & its not that heavy of a system...
Old Oct 19, 2002
VNlilMAN's Avatar
The Standard One
my badd, after reading my previous response, i have no idea what i was saying...
damn thats weird, to have it so off compared to the other side. spec is -1.5 so -1.8 isnt that far from it. if it was me, i wouldnt even bother
Old Oct 19, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
get another alignment made or have your camber re-done for a second opinion but as of now you dont need one!!!
INJEN
Old Oct 19, 2002
VNlilMAN's Avatar
The Standard One
get another alignment? for what? his rear right camber is still going to be off since he doesnt have a camber kit. n he doesnt need one? uh.. its out of spec so it shows he does in order to correct the camber. whether its worth it is another thing
Old Oct 19, 2002
injencivic's Avatar
it just out on the right rear though is what gets me. thats why i recommended a second opinion.
Old Oct 20, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Actually, according to the OEM manual
Front is 0.00 plus or minus .45 degrees
Rear is -1.00 plus or minus .45 degrees
The front kit is only 30 dollars, the rear is 135.
From your printout, the fronts and rears are off. And on my car, there was a big difference in the camber on the rears, but the adjustable links fixed all that.
This topic has been beaten to death, some will say you don't need it. But if you wanting your car to be within specs, then you will need the kits.
GolNat
Jan 12, 2021 09:06 PM
carid
Aug 14, 2015 05:46 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
