ABS LIGHT ON AFTER CHANGING CLUSTER
Old Oct 24, 2002
ducksause's Avatar
ducksause is an unknown quantity at this point
Help me people I just changed my dash cluster gauges from dx auotmatic to ex automatic....everything works find but the ABS light is still on, what can i do to get ride of it?....I've been told by friends to take it to the dealer, but I don't want them to see that I've swapped my cluster. is there anything I can do or must the dealer repair the problem?...and if I must go to the dealer will I get into trouble (legal wise trouble)?? help me guys your advise and comments will be grateful to me.
Old Oct 24, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
maybe because you don't have ABS? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
If that's the case, i don't really think there's anything you could do, but i could be wrong
Old Oct 24, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Quote
[hr]Originally posted by: 01civicboi
If that's the case, i don't really think there's anything you could do, but i could be wrong[hr]
i thought only the ex had abs
Old Oct 24, 2002
01civicboi's Avatar
Quote
[hr]Originally posted by: Smokie2k2LX
Quote
i thought only the ex had abs[hr]
that's why I think his light is coming on. He's driving a DX, which i don't think has ABS, and the cluster usually receives an ABS signal or something and since it's not getting one, the warning light is on. that's my theory [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 25, 2002
Boosted2k2's Avatar
I agree
Old Oct 25, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
The dx does not have abs, just pull the light bulb out from behind the cluster. you should be fine.
I did the swap to a lx cluster and that does not have the abs. Only ex
Old Oct 25, 2002
Macko's Avatar
Macko is an unknown quantity at this point
Isn't there a ABS fuse? somewhere ? if so pull that out[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 25, 2002
Boosted2k2's Avatar
Quote
[hr]Originally posted by: Macko
Isn't there a ABS fuse? somewhere ? if so pull that out[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
yeah, but is there an abs fuse in a car with no abs? Do what jeff said and pull the bulb.
Old Oct 25, 2002
YS's Avatar
YS
YS is an unknown quantity at this point
put a black tape behind the cluster to coveer the abs
Old Oct 25, 2002
YS's Avatar
YS
1. Only EX has ABS
2. you cannot pull the bulb, because it use a LED
Old Oct 25, 2002
ducksause's Avatar
I thank you guys for your comments, my dx does not come with abs, so how would I get rid of the light, I would deal with it since I know it won't damage my ride but you guys know that the light can get annoying after awhile, geez even my selt light annoys me lol
but seriously guys can i get rid of it somehow????
Old Oct 25, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Quote
[hr]Originally posted by: YS
1. Only EX has ABS
2. you cannot pull the bulb, because it use a LED[hr]
You can pull the bulb because I pulled all mine when I went to reverse indiglo and then replaced them all except one. You just have to find the right one to pull.
Either pull the right LED out or like somebody else said, put a piece of black electrical tape over the light. It'll work.
Old Oct 25, 2002
CivicManDan2's Avatar
CivicManDan2 is an unknown quantity at this point
yup, thats basically what i did. only if i remember right, the LED was hard wired into the board so i think i just broke it off.
Old Oct 25, 2002
ducksause's Avatar
Once again thank you guys for your help and ideas on how to solve this problem. I think I will go with putting a piece of black tape over the light, in fear that if I try pulling the ABS bulb out I'll probably break some lol. The gauges work well but I realizes two more issues when I put my turn signal on it doesn't show it on the dash but they work...and it doesn't tell me that my high beams ae on when i put them on. Do you guys think I'll pass inspection even thou my turn signal is not indicated on the dash board???
Old Oct 25, 2002
TACHITUP's Avatar
TACHITUP is an unknown quantity at this point
when the abs light comes on is when your abs won't work because one of the parts on that circuit are bad(or in this case all completely missing) . i would just try to get something in there to cover up the light. might have to pull it all apart. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 25, 2002
Roadog's Avatar
Roadog is an unknown quantity at this point
The LED is soldered to the circuit board. I had the same thing happen when I put a cluster in my friends DX. I just unsoldered the LED and took it out.
Old Oct 25, 2002
ducksause's Avatar
okay fellas I took the cluster out again and tried looking for that bulb ya'll told me about found it but I could pull it out nor brake it, so I just took a black magic marker colored in the ABS light then put a small piece of black electrical tape over it (ghetto tatics) lol....
I thank you guys for your help and advise, but I have one last question?
my turn signal can not be seen in the cluster (but from the exterior of the car they do) will I fail inspection because it can't be seen in the cluster?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 25, 2002
Hedonism's Avatar
Hedonism is an unknown quantity at this point
do what I did, open it up again, look down and you see 2 leads, get a knife a cut one, and there you go no ABS light. i did this about a year ago
[IMG]i/expressions/demon.gif[/IMG]
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
bahena08
Apr 11, 2015 05:09 PM
fordfocussucks
Dec 7, 2001 02:54 PM
