ENGINE SWAP WIT H RSX TYPE-S MOTOR??
Old Oct 31, 2002
joepilot311ta's Avatar
joepilot311ta is an unknown quantity at this point
Hey whats up guys. I talked to hasprot yesterday they said they will be offering a kit that allows the RSX engine bolt up to our cars!! Great I am doing that swap immeditely after that kit comes out. BUt the question I have is, is there a turbo out for rsx-type-s? If so where can I get it? Also when I called the dealer who sells the engines, ($6,800w/low miles and 6speed gearbox) he said they have the type r motor!! Is there such thing as an Acura RSX- Type-R?? thanks in advance for any replies
Old Oct 31, 2002
CarbonFly's Avatar
Yes, there will be an RSX Type R
Old Oct 31, 2002
taz757's Avatar
RSX TypeR is the JDM Integra.
Old Oct 31, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
and u can get it at JDMHondaParts.com
please people do a search
Old Oct 31, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
The RSX-S has a high compression ratio (11:1), and the JDM Integra-R Motor has an even higher compression ratio, (11.5:1). Not to say that that couldn't be fixed, but for a turbo setup you'd typically want a low compression engine to start with, or the process could turn out more expensive than planned.
Not too mention I'd hate to see you do the swap, and then buy the turbo kit only to have your boosting dreams halted by fitment issues, after you're already 10$k down the hole.
Old Oct 31, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Welcome to the fourm member 8666 (woah..nice evil member number you got stuck with :thedevil[IMG]i/expressions/face-icon-small-wink.gif[/IMG], you might want to check out these two threads, they WILL answer your questions.
Thread Number One (First 2k1Civic w/ K20A2 Swap)
Thread Number Two (HASPORT's mount kits)
Old Oct 31, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
the jdm engine would be ideal for NA...........just like the dc deuce. hell, even the usdm type-s motor already has lots of NA parts for it
edited for spelling
Old Oct 31, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
Type S Motor: 6-Speed 200HP
Type R Motor: 5-Speed 220HP
I could be wrong (and usually am) but I believe those are the most significant differences between the Type-S & Type-R
Old Oct 31, 2002
dragoon's Avatar
the type r also has a 6spd. the dc2 type r is the one with the 5spd
Old Oct 31, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
For turbo all you will need is any K20 engine. If you are going naturally aspired. it would be the same unless you do not intend to rebuild the engine in any way or form. If you want a good reliable engine, get the R, if not go through all the hardships and build one. Building one is half the battle and the most fun.
Old Nov 1, 2002
huyqvu's Avatar
huyqvu is an unknown quantity at this point
rev hard has a kit out, and drag is coming out next spring. and this is for the k20.
cloudguy
Apr 28, 2015 05:02 AM
TaiChi
Dec 17, 2001 09:09 PM
Sledge
Dec 7, 2001 12:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
Vtecpwr
Nov 11, 2001 10:17 PM
