i have 2.25" pipe and i wanna change it...
Old Oct 22, 2002
VTecnology's Avatar
VTecnology is an unknown quantity at this point
...to 2". I wanna keep it down cuz its just too loud and annoying. and i think my exhaust have a leak too. will this be a good idea? what smaller size do u guys recommend?Thanks
Old Oct 22, 2002
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
I say 2" is the good. If you go any lower you'll be as stock. I believe that Stock is 1.75".
Old Oct 22, 2002
VTecnology's Avatar
It will be quieter, right?
Old Oct 22, 2002
EManEX's Avatar
if you want quieter why not just buy a resonator and have it put on. That way you won't have to spend more on a whole new system.
Just a sugestion.
Old Oct 22, 2002
VTecnology's Avatar
the way the shop did mine, they enlarged the opening of the pipe that connects the muffler to the pipe to the cat to connect the two. plus its 2 separate pipes from the cat to the canister. i'm thinking theres a leak becuase the it sounds a lot different from other exhaust that i've heard. its louder too.
BTW i have a 5zigen muffler
Old Oct 22, 2002
XxJDMCivicxX's Avatar
you have 5zigen universal exhaust and have custom piping done? I was considering doing 2.25" piping is it really loud though or is it cuz of the might be leak? Cuz i also have a 5zigen exhaust
Old Oct 22, 2002
VTecnology's Avatar
i really think that theres a leak. Im gonna go tomorrow to a muffler shop to change the 2.25" pipe to a 2.0" pipe. pls tell me or
Old Oct 22, 2002
Alex1's Avatar
yes do it 2 inch gives u more torque like u did stock and also gives a better response on fast speeds.
Old Oct 22, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
i had that setting 2.25 no resonator with 5 zigen fireball..
it wasn't dat loud.... comparing to my hks hiper.
Old Oct 24, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
stock is 2", but youll actually get 2 benefits, youll regain the torque you lost with the bigger pipe(lost some backpressure), and youll gain a little powerover stock, maybe .3hp, because of better flow from the custom(im assuming madrel bent?) tubing, not that that matters, but since itsll be smoother flowing youll gain a MPG or so.
as for loudness, i doubt itll really quiet it that much, you prolly have a leak, easy way to tell, have the car running(in neutral of course) and go from where the aftermarket exhaust starts, all the way to the tailpipe. run your hand over the pipe, not on it, but sort of "hovering", if there arent holes in the piping, check at the joints, if theres a leak, there will be small pulses coming out, and youll hear it a little too.
hope that helps.
Old Oct 24, 2002
aZnVoYCe's Avatar
Quote
[hr]Originally posted by: EManEX
I say 2" is the good. If you go any lower you'll be as stock. I believe that Stock is 1.75".[hr]
Stock for our car is 1".
Old Oct 24, 2002
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
2" is good.. i've got that with a Magnaflow muffler and a glasspack, and it doesn't sound bad at all..... of course, it was waaaaaaay more louder and annoying with just a 2" and Magnaflow. i'm not sure how the 5zigen sounds though...
Old Oct 25, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
No car benefits from backpressure. You want your exhaust to flow as much as it can and the 2.25 will help over the 2.00. Put on a free flowing resonator instead. The smaller your pipe diameter, the higher the pitch of your exhaust. I've got 3" on my '69 mustang (500+ hp) and it rumbles way down low...
boostedboxer
May 25, 2015 10:05 AM
tattedlariat
Apr 17, 2015 03:26 AM
popsiclepete
Canada West
Dec 1, 2001 02:04 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 22, 2001 03:17 PM
fordfocussucks
Nov 6, 2001 03:16 PM
