E Brake Aluminum Handle from eBay, How to Install?
Old Oct 17, 2002
Chickapea's Avatar
Chickapea is an unknown quantity at this point
Anyone ever bought one of these and have actually installed in their Civic 2 or 4 Door model?
If so, how?? Instructions would be nice.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] brake handle.jpg (48 Kb)
Old Oct 17, 2002
KRAYZYDRAGON's Avatar
KRAYZYDRAGON is an unknown quantity at this point
pop the silver top off with a flat head... cut the stock handle off with a sharp knife... put the aluminum handle next to it so you know where you have to cut... make sure you cut it straight... when your done just slide the aluminum handle over and tighten the screws and your done... by the way the TYPE-R is a sticker i suggest u not stick it on the handle... i have that handle but the chrome one it looks cool...
Old Oct 17, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Please tell me youre not putting a TPYE R handle on your car!!! anyways, to each his own.... I put a carbon fiber handle on mine.. I had to first cut the plastic sleeve off, then I had to use a hacksaw to cut some metal off, you'll see what I mean once you cut the plastic. THen I used a file and the handle just barely fit, but I like it. Good luck with your install!
Old Oct 18, 2002
Chickapea's Avatar
but how did you get it passed the button on the brake handle? Know which one I'm talking about? The button you push in to lower the lever is bigger than the hole for the handle to slide through. Did you have to pop off the button or what?
Old Oct 18, 2002
it's a cap just pull it off of the button...
Old Oct 19, 2002
Chickapea's Avatar
thanks
Old Oct 19, 2002
no problem...
TiggerDX
Jun 18, 2015 01:43 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
bsmiley
Apr 27, 2015 01:27 PM
nickeynick
Apr 27, 2015 01:23 PM
