20 K Service??
Old Oct 29, 2002
JohnnyLee's Avatar
7thgen guh chee
20 K Service??
I just hit 20 K mile like last week and was wordering is there anything special the dealer does that needs to be done at 20 K or can I just do my own oil change and rotate the tires by myself[IMG]i/expressions/face-icon-small-confused.gif[/IMG] If I really have to it will get the service for 20 K if not it can wait til 30 K I guess. Any replies will be helpful thanx
Old Oct 29, 2002
sevenincubus's Avatar
sevenincubus is an unknown quantity at this point
I am at 28k and have received two maintence req'd lights already but I'm just too lazy to go to the dealer. I reset the light and I normally change my own oil. No problems so far. I do know its probably brings down my trade in value but oh well. I'd also like to know what services are actually done when you're suppose take in your car.
Old Oct 29, 2002
JohnnyLee's Avatar
7thgen guh chee
Quote
[hr]Originally posted by: sevenincubus
I am at 28k and have received two maintence req'd lights already but I'm just too lazy to go to the dealer. I reset the light and I normally change my own oil. No problems so far. I do know its probably brings down my trade in value but oh well. I'd also like to know what services are actually done when you're suppose take in your car.[hr]
Man I am lazy and don't have the money for the service. I totally understand about the trade value goin down and about ther services that are done to my car. Thanx for the reply
Old Oct 30, 2002
816CvC's Avatar
816CvC is an unknown quantity at this point
if i remember correctly, at 20k they change your fluids and do the 24 point test along with the rotating of the tires. i can't remember for sure so don't quote me. i am getting ready to go in for my 25k check up though and i'd be happy to tell you what all they did this time around though
Old Oct 30, 2002
Russps's Avatar
Russps is an unknown quantity at this point
To quote my dealership, "there is no 20K service.....there is a 22500 service, that includes oil change, tire rotation, and brake service (they FINALY made my parking brake tight!)." They also found I had a leaky strut and replaced it.
Old Oct 30, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Straight out of the manual for severe conditions...
A Replace engine oil and filter
B Inspect front and rear brakes
Rotate tires
Lubricate all hinges, locks, and latches with multipurpose grease
Inspect tie rod ends, steering gear box and boots
Inspect suspension components
Inspect driveshaft boots
C Check parking brake adjustment
Inspect brake hoses and lines (including ABS)
Check all fluid levels, condition of fluids, and check for leaks
Inspect cooling system hoses and connections
*INspect exhaust system
*Inspect fuel lines and connections
Check all lights
Inspect the underbody
Here's what honda should do anyway when you pay for an oil change...
Off of American Honda Ownerlink Webpage
ExpressChange service provides you with high quality, convenient routine maintenance to keep your Honda in top condition. Our quick oil and filter change service and 19-point inspection take 30 minutes or less at participating dealers. And ExpressChange service is performed by Honda Trained Technicians using Honda Genuine Parts, so you can be sure your Honda is in good hands. All this at a competitive price!
When you visit your Honda dealer for ExpressChange service, experienced technicians will:
Replace your oil filter with a Honda Genuine Oil Filter
Check operation of your vehicle's horn, windshield wipers and parking brake
Check operation of high and low beam headlights, tail and brake lights, parking and backup lights, turn signals and hazards
Check your brake fluid level
Check fluid levels (and fill where needed) for your vehicle's battery, power steering, transmission, clutch (if applicable) and windshield washer fluids
Check coolant level and fill if necessary
Inspect wiper blades
Inspect external drive belts and radiator hoses for excess wear
Check clutch pedal for free play (if applicable)
Inspect tire wear patterns
Check tire pressure
Inspect condition of your Honda's suspension and CV boots
Inspect condition of the exhaust system
Check for fluid leaks
Why go anywhere else? Contact your Honda dealer to check hours of availability. Then just drop in, or call ahead to schedule an appointment for ExpressChange service - whichever suits your schedule best! After all, who knows your Honda better?
Hope this helps...
Old Oct 30, 2002
JohnnyLee's Avatar
7thgen guh chee
Thanx for the help so maybe I should do it then[IMG]i/expressions/laugh2.gif[/IMG]
speedlever
Sep 24, 2015 07:18 PM
WWJD
Sep 23, 2015 12:56 PM
Jrosa
Sep 14, 2015 08:24 PM
