oil pressure guage edit* attn honda techs
Old Nov 3, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
oil pressure guage
i am considering buying a vaccume guage, and an oil pressure guage....for the simple reason of looks.....but anyhow, i can figure out how and where to hook up the vaccume guage, but where would i tap into for the oil pressure guage? in case it matters, the oil pressure guage has an eletric sender unit...
mark
edit:
go here
illus # 12, the oil pressure switch....is this an on/off switch? or does it have a varrying output, similar to a sender unit? does the ecu monitor actually oil pressure? or does it just monitor whetere there is appropriate pressure or not...
Old Nov 3, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
the oil guage goes to the oil line. you have to cut the line and put the tee in.and y do you need a vacuum guage???
Old Nov 3, 2002
mwwhonda's Avatar
why do i want a vaccume guage? because i dont have a turbo...and i like to watch guages that move.....[IMG]i/expressions/laugh2.gif[/IMG]
Old Nov 3, 2002
civichx81's Avatar
well how would you hook up the vacuum gauge? dont you need a turbo to do that?i hear you need to hook it up too one of the vacuum lines...
Old Nov 3, 2002
mwwhonda's Avatar
when a car does not have any means of forced induction, the engine is constantly under vaccume.....you can use a vaccume guage just like you use a boost guage, as the load of the engine increases the vaccume will increase.....in order to hook it up, you simply need to T into a vaccume line
mark
Old Nov 3, 2002
civichx81's Avatar
oh cool!!!that i didnt know... maybe ill get a vac guage now and see. is the vacuum line the one near the throttle body?
Old Nov 3, 2002
mwwhonda's Avatar
im not exactly sure exactly where i will tap the guage into yet...there are lots of vaccume lines...well, there might not be w/ our engines..but im sure i could find one...i think you might even be able to tap into the connection from the top of the valve cover (the breather pipe that connects the air intake to the top of the valve cover)
mark
Old Nov 3, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
Where the oil pressure switch is you should be able to install a t-fitting so you can have a spot to screw in your electrical sender. If you goto an auto parts store they should have a hydralic t-fitting that will fit. The oil pressure switch is right above the oil filter. I'm not sure what size it is. What we really need is someone who has installed an oil pressure gauge! Anybody, anybody....
Old Nov 3, 2002
mwwhonda's Avatar
well, depending upon wheter or not autometer will release the guage pods for our cars...will determine if this project happens.....supposidly autometer releases there new products within the next few weeks, hopefully our 7th gens will have a place in there hearts....
mark
Old Nov 3, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Look just behind your intake manifold, you should see a black vacuum line, about as thick as a pencil. T into this one for your vacuum gauge.
Old Nov 3, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Quote
[hr]Originally posted by: mwwhonda
mark[hr]
Autometer already has gauge pillar pods avaliable for 7th gen civic coupes only. They are avaliable to purchase from any autometer dealer. The sedans however are quite a few months behind production since autometer had overlooked teh difference in teh structur between teh coupe and sedan. but theres no reason to worry because sedan pillar pods will be out soon, along with the dash bezel pods.
Old Nov 3, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
sleeper civic has it correct. Buy a T fitting (not sure if it is special, but the del sol's was very very hard to find) and you can tap into the oil pressure switch fitting. Secondly, someone used to make an adapter that fit into the oil filter threads and allowed an oil pressure sender to be tapped in.....
Old Nov 3, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
I have the one made for a 97+ prelude and it fits perfect
Old Nov 4, 2002
mwwhonda's Avatar
i just spoke to autometer, and they do not have a listing for a guage pod for the 7th generation, coupe or sedan....[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
artychris
Nov 11, 2001 10:23 PM
