PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. engine type
  2. quick ? about hyperblinker DIY
  3. Clearing headlight ??'s
  4. The Splash Guard shield for the engine? Fell off...
  5. more performance needed !
  6. where to buy clutch ?
  7. Whats next in the performance department?
  8. Ram air intake
  9. header is glowing! ahh
  10. Questions about stripped lug bolt
  11. New Angel Eye Question
  12. HP Racing header
  13. DX cluster upgrades FAQ.
  14. Gutting the CAT
  15. Any way to reset the odometer?pls help
  16. Altezzas and Projector headlamps
  17. how to make clear taillights black???
  18. how do you take the plastic out the 01 front bumber?
  19. Both CAI and SRI?
  20. Moisture in headlights???
  21. ???
  22. 2 pulse tach hookup
  23. how to tell which wire is which in ECU?
  24. HP header
  25. removing nuts on rear strut towers?
  26. engine noise when i shut off
  27. o2 sensor
  28. Aem V2
  29. air bags...
  30. HELP: Need help, problem with car
  31. Just to make sure I get this right...
  32. sidemarker wiring
  33. NOS Jetting Sizes?
  34. Ceramic paint additive as insulation?
  35. Header question-need quick answer
  36. Crashed-Suspension @$#%
  37. What to swap manual door locks
  38. Sensor Question
  39. My intake goes woo woo
  40. installed OEM kit on sedan!
  41. D17 interchangeability
  42. Wasting Gas?
  43. whinning noise??
  44. relocating engine bar
  45. How Do You Align Headlight Beam?
  46. IAC strange sound
  47. sidemarker install help
  48. Type A lip kit install...some general questions
  49. rs grill
  50. street glow help
  51. removing stock intake box?
  52. o2 sensor bung
  53. ECU swapping??
  54. ebay intake&throttle body spacer ?
  55. e-bay intake problem :(
  56. Rsx piping
  57. wheel creak
  58. check engine
  59. B series motor help
  60. tint paint touch up?
  61. Body Kit Question
  62. header rattle?
  63. s2000 seats in 03 coupe.
  64. Civic Exhaust
  65. do projector light come with harness?
  66. Just changed tranny fluid!
  67. trunk remote?
  68. 120 octane in a civic...
  69. shift grinding
  70. Head Porting for beginers
  71. remote start
  72. HALO altezza
  73. HELP.. emrgency brake problem
  74. throttle body
  75. Help On Replacing Wheel Stud?
  76. DIY: o2 simulator *updated with 7thgen instructions*
  77. srs light w/ rsx seats
  78. Need a new radiator, Which one?
  79. HEader question
  80. Installing indiglo
  81. help pls. asap.
  82. Exhaust question
  83. Will Intake....
  84. Sidemarker direction
  85. Where I can get part numbers for my car?
  86. Where can I find Kamikase header?
  87. cranking sound?
  88. Windshield Crack
  89. 7th gen recall for ignition?
  90. Indiglos making a high pitched noise somewhere
  91. vinyl decal tips?
  92. Turn signals
  93. Thermal and HKS rear section
  94. Revo Technica Short Shifter and RSX Shift knob
  95. Hi Help Plz
  96. Popping out a dent
  97. civic si sway bars better ?
  98. Weird... 92 Octane really does help us...
  99. Torsion bars for aftermarket speakers?
  100. Quick 12v question
  101. rear strut brace install????
  102. rear disk conversion
  103. tightening trunk latch
  104. Turbo Charged V.S. Super Charged
  105. removing the outlet help!!!
  106. oil pan dent
  107. slave cylender???
  108. Muffler shop make silencers?
  109. e-brake BUTTON??
  110. ??
  111. Install help
  112. Just got an oil change (used 10W40
  113. Just got rear-ended. Help!
  114. Apexi World Sport Exhaust....
  115. HP racing
  116. Which way does the coolant run through the radiator?
  117. Question?
  118. Bigger Injectors Q's
  119. how do i change my shift knob ?
  120. cold air intake
  121. Custom Final drive ratio
  122. Prototype Mugen digital instrument panel
  123. Rear Lip Help!!!!
  124. K24 swaps
  125. Cold air intake on HX
  126. timing belt?
  127. aem sri
  128. header torque spec.
  129. Acura HID
  130. cam gear install
  131. 98 accord tranny swap?
  132. RSX engine swap how to pull engine with minimal tools
  133. ok.. last guage question
  134. how to paint silver trim piece around shift boot?
  135. srs light
  136. another dang guage question
  137. Clearing TYC projector!?
  138. Longtime Since I've Posted
  139. msd on 7th gen
  140. Has any one ever tried...
  141. how to remove bulbs?
  142. oil pressue guage
  143. bulb color change
  144. BIG tip on painting interior trim pieces!!!
  145. which brake pads to buy?
  146. alternator diagram
  147. 99 accord headlight help
  148. how many miles can you go over after oil change request?!
  149. cam shaft
  150. cam shaft
  151. Header Heat shield?
  152. removing ac and ps belts for racing ?
  153. blue led for alarm?
  154. header for dx?
  155. i need help really quick guys
  156. Condenser out!!!
  157. Front Bumper Question
  158. driving slow is bad for car!
  159. Pep-boys Breather
  160. Chip For 01 Civic Ex
  161. Battery
  162. Carbon Fiber HELP
  163. HELP - Clearing headlights at this moment!
  164. will this work?
  165. neons and fog switch?
  166. Headers: Stainless vs Ceramic...
  167. cam gears?
  168. aem cam gear cheap !
  169. Just Shift Light
  170. Psuh Button Starter Igniton
  171. Will RSX parts fit 7thgens?
  172. headlights question
  173. Door won't close tight. Warranty Q?
  174. Power Windows - Stock Parts
  175. Altezza grill install
  176. Calculating 1/4 mile times.
  177. Fixed my exhaust-bumper problem...hope this ain't a repost
  178. header question
  179. Help My power door locks don't work!!!!!!!!!
  180. aem cam gears ! hookup
  181. projection head lights
  182. Tsunami front bumper question
  183. Have some ?'s about engine swap (not 7th gen vic related)
  184. wiring help please
  185. i need help fast this is serious PleasE
  186. two tachometers
  187. Fuel Signal
  188. fuel pump problems
  189. 2004 civic
  190. Owners of a Kaminari Rear Skirt!
  191. needle color on gague cluster
  192. HP Header Problem!
  193. Hydrolocking
  194. Clearing Sedan Headlights...
  195. cd player
  196. Venom in my A/F ?!?
  197. Pop Trunk ? Impossible?
  198. Mid pipe, B pipe question?
  199. problem with the vcn1000 kit
  200. how is this kinda dash done?
  201. Engine shaking?
  202. double clutch....Good or Bad?!?!
  203. 5w-20 oil - Necessary or Recommended?
  204. Several ?'s about Rust and Jacks
  205. Anyone know how much HP the stock axles can take?
  206. Body Kit Installation Question
  207. Drag Racing X-mas Tree
  208. Belt Noises
  209. I need a confirmation of my thoughts on removing valve cover issues...
  210. Concern about our oil system...
  211. help with S2000 pust start ignition button
  212. AEM intake
  213. where is the temperature switch in my 95 civic dx hatch -
  214. Which sensor monitors heat?
  215. Yet another "paint your headlights black" question...
  216. nitrous windowswitch
  217. Front axle noise???
  218. New windshield wipers???
  219. OEM civic keyless entry
  220. removing factory hood prop?
  221. anyone change pads on a ford ranger?
  222. how do you paint a grill?
  223. painting the headlights black
  224. correct way to drive with Nitrous...
  225. The Little Bolt That Could
  226. Garage door opener?
  227. fuel pump
  228. stock downpipe size
  229. need help???
  230. where to buy this........
  231. Honda OEM Brake Pads
  232. aiming washers
  233. gear ratios??
  234. running car w/o 02 sensor?
  235. Any Suggestions or Answers>>??
  236. Is this where the fog lights go?
  237. Can I connect the pos. of my LED washers here..
  238. whats an O2 simulator
  239. Bypass Valve on DX Intake
  240. Header install help....
  241. Mounting Fiberglass Bumper
  242. is this good ?
  243. v-tech convertion
  244. kms install question
  245. DIY: Make SRS light gone without airbag install ( racing steeringwheel )
  246. k&n filter vs heatshield filter
  247. is this worth $60 ?
  248. Gas Question
  249. Headlight Clearing Question
  250. Question on painting interior pieces
