Clearing headlight ??'s
Old Oct 14, 2003
richash2's Avatar
richash2 is an unknown quantity at this point
Question Clearing headlight ??'s
I am plannning on tackling clearing my headlights this weekend and was wondering if any one could tell me some details and how hard it is, and if there is any big things i should know and one more thing what do you put the headlights back together with any kind of special glue or something?? well thanx alot guys
Old Oct 14, 2003
cambo's Avatar
I wish I was asian
all you need to know is here.
oh and oven set at 200 degrees for 5-9 minutes.
Old Oct 14, 2003
richash2's Avatar
It tells you no where how to put it back together and what to use can you please explain it a little more thanks
Old Oct 14, 2003
Mr.Modify's Avatar
i didn't use no oven just good old fashion muscle!!
Old Oct 14, 2003
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
clearing headlights?? seems like a tough job i mean i would like to clear mines but its a 50/50 shot it would work then i would have to seal the headlamps and i damn sure dont know how to do that
Old Oct 14, 2003
damn dude.. u sure you didnt cut the sealant before prying it apart with all muscle? i'd imagine you'd break the sucker first... if not, then i stand corrected..
Old Oct 14, 2003
Mr.Modify's Avatar
okay okay...well i used a flat head screw driver and muscle!!
Old Oct 14, 2003
just buy some sealant from home depot or something.. something that will preferrably harden.. then just coat the gap of the 2 outermost pieces with the sealant, let it harden, then put back on your car... i personally havent done it yet, but will prolly do it when i get my car back...c'mon people... its common sense... at least for me..
Old Oct 14, 2003
Mr.Modify's Avatar
or you can go to pep boys to!! that's where i got mine!
Old Oct 14, 2003
cambo's Avatar
I wish I was asian
how do you put it back together? put 2 and 2 together... that like asking how to set-up a monopoly board. You'll have two big peices left. if you cant figure it out, you wont be getting anywhere in the car tuning world.
jus buy some silicone sealent. some people had enough OEM sealant left on their headlight that they jus reheated it and pushed it together real good.
Old Oct 14, 2003
richash2's Avatar
at pep boys is there a specific type of sealant to buy like headlight sealant or something?? we changed plans we are going to do this 2maro me and my dad. he has a heat gun and he said he thinks that should work to break the seal, he said that he had to do it on a couple of hims limosuines, (We own a limosuine service)
Old Oct 14, 2003
civicvtec1ps's Avatar
Search and Learn
you just need to buy any sealant. just get bathroom waterproof silicon from any hardware store. DIY is not hard.just follow instruction
Old Oct 14, 2003
ptechricer's Avatar
ptechricer is an unknown quantity at this point
there was enogh sealant left on my headlights that they just stuck back together and you dont need a heat gun, just use a flat head screwdriver and muscle. It is easy I have done it several times.The main think to watch is dont get the stock sealant on the headlights they dont come off.
Old Oct 14, 2003
JayFReaZy's Avatar
when i cleared my headlights it was a b!tch. People say use muscle and all'at ****, but its still damn hard to pry it open. Best bet is to use a hair drier. Put it on high, and blow dry the edges, your gonna need another persons help. One can blow dry the edges while you pry it open, its 100x easier. I didnt like the idea of puttin my headlight in the oven, so the hair dryer was the next best thing, and it came out perfect.
Old Oct 15, 2003
richash2's Avatar
im going to go do it now after school, ill post how it went afterwards
Thanks for all the help
Old Oct 15, 2003
7thGENDMAN's Avatar
7thGENDMAN is on a distinguished road
It is alittle harder then you guys make it sound. If you heat up the glue it just makes it that much easier to pull the two pieces apart. The info I can give you from doing this to two sets of headlights is the warmer the better. Using the oven will get the whole headlight to an even temp, rather than using the heatgun, this will help in pulling the two pieces apart. The heatgun will only heat up one section at a time and makes it real hard to pull them apart with only a small portion of the glue melted. If you heat the whole headlight, All the glue will be warm and it makes it very easy to pull them apart, using just MUSCLES. When putting them back together, the heat gun will work. First, use it to heat up the glue, then put the two pieces together and squeeze, and if you heat it up a little section at a time you can just about squeeze them back to normal. I had plenty of glue on both of my sets, that I didn't need any sealant at all. No moisture what so ever. Let us know how it goes.
Old Oct 17, 2003
frenchis's Avatar
frenchis is an unknown quantity at this point
or just buy new headlights
Old Oct 23, 2003
Alexander13's Avatar
ASS BANNED-IT!
Alexander13 is an unknown quantity at this point
Hey after you heat up the light and seperate the two halfs make sure to have the patience to let the black evil goo of death cool before you remove the frame from the lens cover. cause if your not planing on painting them then you may end up painting them (it looks better anyways) just to cover up your mistake of getting that crap on your crome (good luck getting it off and not f**king up your finish)
This is the best bang for the buck so do it, just take your time give yourself a whole day to get it don it took 6 hours for me (mostly waiting for paint to dry)
PS: if ya paint um use primer dammit!
Name:	dcp_0009 (large) (small) (small) (wince).jpg
Old Oct 23, 2003
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
i have a question... where do you guys get the little orange reflector that goes under the turn signal/next to the parking light?!
Old Oct 23, 2003
frenchis's Avatar
*** for 129 bux i just bought brand new projector head lights, screw takin out the reflector, plus it gives u that euro look/bmw
Old Dec 24, 2003
ZodCivik's Avatar
All original
its just half of the stock orange reflector
Old Dec 24, 2003
dezod's Avatar
7thgen Power Maker
Re: Clearing headlight ??'s
If your that scarred of doing it, why don't you just buy a clear set.
http://dezod.com/pd_metallica.cfm
"Very RARE-JDM Style Headlight Housings w/ Cleared lenses $149.00 (on order) Need bulbs with it? Add $30 and receive Xenon H4 HL bulbs, Hyper White 194 Wedge bulbs & orange 7443 turn signal bulbs. $25 to ship anywhere in the 48 states."
Old Dec 24, 2003
putang inamo!!!
Originally posted by ZodCivik
All original
yeah, just found out after i posted that question. im thinking of just stain glassing it yellow along with yellow corners, something different =) ..... thanks ZodCivik
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
brash99
Sep 29, 2015 08:42 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
