Adjusting TYC low beam...
Old Dec 17, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I will be retroing Audi projectors within the next month, but for the mean time, the halogen low beam is too low.. i need to adjust it...
How do you do it?
I only see adjustment screws for the high beam...
and also...
for when i retro...
when you guys mounted OEM projectors in the TYCs, how did you make them adjustable? And whats the best way to replace them? (Bake in oven and seperate front cover?)
Old Dec 17, 2003
Dr5D's Avatar
I wan tto know how to aim my TYC also
Old Dec 17, 2003
NeonImpact's Avatar
Forum Sponsor
i typed this up a looooooooooooooonggggggggggg time ago:
Ill be nice before you get flamed on..
1. Remove Bumper (see DIY)
2. Remove 4 Bolts All Around Headlight Housing
3. Remove Old Headlights
4. Install TYC's
5. Put 4 bolts back in
6. Plug in TYC Connector install Factory Connector
7. Turn on Lights and Test
8. If Working, Line up against a wall and adjust
9. See bottom of this page for adjustment procedures.
10. Put bumper back on
11. Go Cruise.
12. Learn to search the site
13. Thank me
14. Have Fun
** No cutting, splicing, opening, nothing!**
**BTW, Nice car man!**
How To Adjust:
**TO MOVE BEAM UP on the DRIVER-SIDE**
turn the outer(lower) screw counter-clock-wise
**TO MOVE BEAM UP on the PASSENGER-SIDE**
**TO MOVE BEAM TO THE RIGHT (towards the plate) on the DRIVER-SIDE**
turn the inner(upper) screw clock-wise
**TO MOVE BEAM TO THE LEFT (towards the plate) on the PASSENGER-SIDE**
(Thanks to falken for that DIY on previous thread)
I know you'll be sure to ask in the near future so check back for this if needed:
WHAT BULBS ARE IN THE PROJECTORS??
High Beams - H1
Low Beams - H1
Parking Lamp - 194
Turn Signal - 3457 (3156, 3157 work also)
Best Bulbs to Buy?
I have worked with MTEC, Eurolite, And Many Others and yes, every bulb will be bright just about, so its your choice of opinion..
MTEC are bright as hell and prolly the highest rating on the site.
Stock bulbs have worked for me perfectly fine, so its your decision..
Remember about laws against the bulbs..
The best way to go is get a H.I.D. Kit made by phillips or out of a lexus, bmw, or whatever..
Hope this helps..
Old Dec 18, 2003
MangoEX's Avatar
Just Be
What bolts are you referring to? Please be more specific
Old Dec 18, 2003
Dr5D's Avatar
there are bolts on the backs of the housings
Old Dec 18, 2003
acidbaby's Avatar
The Beez Kneez
Re: Adjusting TYC low beam...
How do you do it?
and also...
for when i retro...
dont bake it man there is too much room for error .just get a heat gun they are not very expensive, or you could use a hairdryer
Old Dec 19, 2003
FuzzBeC00L's Avatar
Fuzzy Boy
NeonImpact good move
Old Dec 19, 2003
ImPulse's Avatar
Re: Re: Adjusting TYC low beam...
no not really =] set the oven to 330 degrees > turn it off, wait for the RED coils to disapear , then put the tycs in the oven... Try to keep them away from the sides of the oven... Keep them in there and WATCH them for 8 minutes then take em out
take a screw driver or butter knife and pop the clips and pry it apart (hardest part of the whole ****ing thing). My fingers kept getting burned =\
Also, scrap all the aftermarket sealent off right away because you will need to put them back together @ t he end... mind aswell take the old stuff off there because its the most annoying part.
Old Dec 19, 2003
ImPulse's Avatar
A good move would have been to put this thread in the
"I.C.E. & Electrical » Lighting" section
Old Dec 19, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
LMAO ^^^
Old Dec 24, 2003
Handsonme's Avatar
Neon, that is the best post I've seen you post.
LOL (cuz it's the first one that has helped me).
=D merry xmas
EdGasket
40
Nov 27, 2015 11:11 AM
fred57
Aug 1, 2015 08:45 AM
jessica19699
Jul 30, 2015 01:02 PM
alxz310
Jul 30, 2015 12:18 PM
Jul 12, 2015 11:54 AM
