shift grinding
Old Oct 7, 2003
BasicEssentials2k1's Avatar
BasicEssentials2k1 is an unknown quantity at this point
shift grinding
my car drives great but when i shift into third... it gives alittle grind once in a while and yes i know how to drive stick ad yes i push in the cluth all the way... what the hell is wrong with it... is there any aftermarket stuff i can buy for it and is it a bitch to install...
do they have aftermarket flywheels...?
do they have aftermarket cluthes...?
do they have aftermarket shift plates...?
or what the hell do i do.. i need advice because the dealership laughed after they saw all my mods on my car and told me my warrenty was voided.
help a 2k1 brotha out
Old Oct 7, 2003
Entropy's Avatar
Entropy is an unknown quantity at this point
your warranty is not allowed to be voided just because you mod your car unless a mod is the direct cause of something failing.
and last I heard around here they have aftermarket stuff for everything you listed.
About the grinding, I'm hoping that by switching to Cap Yoda's aluminum bushings, my shifting will encounter less problems than I have now, mainly dealing with 1st and 2nd gear.
Old Oct 7, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
If you have the clutch to the floor and your grinding into gear, its probably the syncros. If you didn't put a clutch in or mess with your tranny / shift assembly (short shifter etc) then it will be covered. They can't deny you warranty on your tranny for putting an exhaust on...
good luck.
Old Oct 7, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Mine don't grind, I can just feel them if I shift fast, If I shift slow and resonable I can't feel them at all. Do you have a short shifter, cause that will make you feel them even more.
Old Oct 7, 2003
TunedNCivic's Avatar
TunedNCivic is an unknown quantity at this point
Tell the dealership to kiss you where the sun dont shine. They have to cover it unless you modded the tranny. There is a law, I have the paperwork to prove it. If you have a speed shop, rim shop etc. in your area. Im sure they can give you a legal copy of the law. Thats where I got mine.
Old Oct 8, 2003
CivicSouldjaEX's Avatar
Same thing was going on with my car. It was the synchros. I got them fixed by the dealer under warranty. Also a clinking noise when making a right hand turn in second gear is a broken gear thingy that honda dealers got a bulletin for. Get it checked out and get it repaired cuz the grinding will only get worse, up to the point when it'll grind all the time no matter what.
Old Oct 8, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yep ... tell the dealership to goto hell
it's probably from your car being raced to hell ... that's why that happened ... haha ... same thing that happened in my friend's '99 ex and drivetofast's car
Old Oct 8, 2003
cdmx's Avatar
where did you get that W.O.T throttle body?
or if thats not an aftermarket TB what does that mean in your mods.
Old Oct 9, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
how comes the dealer fixed this under warranty ? because this is happening to me 2 ! what kinda mods you have on your car ? because i have i/h/e
Old Oct 9, 2003
blustrek01's Avatar
blustrek01 is an unknown quantity at this point
i acn tell you that it is the synchro that is grinding. the reason that it is grinding is that you bent the third gear shift fork ever so slightly. i know this because i ripped third one day just a bit too fast. hope you can get it fixed under warranty. mine was long gone when that happened. i just got a junk yard trans with only 2k on it for five bills. good luck.
Old Oct 20, 2003
03civicdx's Avatar
03civicdx is an unknown quantity at this point
You have to go to honda america and complain to them and i gurentee they will call the dealership and tell them they have to cover the work because it is true that a cold hair and exhaust is not going to effect your trans at all, Im having a similar problem with 2nd gear and im going to take my car in soon, im just debating wether or not to pt my stock airbox back on and take off my other "toys" as well.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
Bonobo
Oct 2, 2015 06:58 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
