Help My power door locks don't work!!!!!!!!!
Rep Power: 280 Help My power door locks don't work!!!!!!!!!
My car's power door locks do not work. I have no idea why. I checked the fuses and everything is fine.
When my key is in the ignition doors unlock but do not lock.
When my keys are out of the ignition the power door locks do not work.
Like it has no power or something
I have no idea what is wrong with it
I have a 2002 civic ex with the factory alarm.
I checked the wires and I coupld not find anything either that is not hooked up or something
Help Please!!!!!!!!!!!!!!!
I will give points if someone can help me out with this problem
Rep Power: 298 Did you do this while your door was open?
The problems you described happens when you have the drivers door open. Its so you don't lock yourself out.
If not, then I have no clue.
Rep Power: 280 does anyone have the schematics for the keyless entry, alarm and also the power door locks for our cars. The honda dealership said that since I have some mods inside of my car it is going to cost me $215 dollars just to diagnose the problem
let the devil out
Rep Power: 365 honda's factory alarm system uses a negative contact locking mechanism as in if its not closed it will not lock unless you do it manually. The problem seems to be a controller issue which I had on mine at first but was replaced by warranty . Regardless of mods it should not cost you unless you modified the alarm system itself.
MamaBear2015
05-03-2015 02:17 PM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
