sidemarker install help
Old Oct 9, 2003
FLiPKicks's Avatar
FLiPKicks is an unknown quantity at this point
Hey wasup. I read the DIY on the sidemarker as well as Mex's DIY for sidemarker installation. Just one question. Would it be difficult to usea dremel to cut the hole? I was just curious. Because I'm too poor to purchase that sheet metal cutter from Radio Shack. Thanx
Old Oct 10, 2003
you'd prolly end up denting the fender cutting the hole, unless you wanna hammer it out and repaint it before you put the actual sidemarker in..
Old Oct 10, 2003
CivicSky's Avatar
CivicSky is an unknown quantity at this point
I always want to install side markers on my ride but I just don't want to drill holes on the fenders. Can I just put them on the mirrors instead (I heard about those M3 mirrors with LED on the back but I love my OEMs better)
Old Oct 10, 2003
buy M3 style mirrors with the amber or blue LEDs in 'em...
cheap on e-bay...
Old Oct 10, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
The M3's with LED have been known to have the LED's burn out in them.
~nick~
Old Oct 10, 2003
biohazard's Avatar
biohazard is an unknown quantity at this point
How much are those sheet metal nibblers? You could buy them at Home Depot, then return them when you're done... but that would be wrong....
Old Oct 10, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Re: sidemarker install help
The metal nibbler is only $10.
-Kre
Old Oct 10, 2003
TeLLy's Avatar
Yes, it's an Acura EL
If you're experienced with a Dremel you CAN use it and you won't dent.
Old Oct 10, 2003
FLiPKicks's Avatar
well ive cut computer cases with my dremel. I use the cutting discs's and it comes out fine. Is the sheet metal on computer cases thicker/thinner then our fenders.
Old Oct 10, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
be careful not to burn the paint on the fender when using a dremel....u could always buy jdm fenders no cutting that way
Old Oct 10, 2003
nme3's Avatar
JDM wannabe
haha nice avatar
Old Oct 10, 2003
yeh maybe one day i can have a glowing name too in spoon yellow
Old Oct 10, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
lol... glowing name = like 750 points... not really worth it.. i did just for fun
Old Oct 10, 2003
futuremethods's Avatar
Future Member
futuremethods is an unknown quantity at this point
I used a dremel for mine. Use cutting discs to cut out the bulk of the area and grind the rest down to spec. Just keep a firm, steady grip and don't rush yourself. And make sure to wear eye-protection because the cutting discs WILL break. Good luck!
Old Oct 10, 2003
FLiPKicks's Avatar
hey thanx for the help guys. I'm going to start cutting tonight.
Old Oct 11, 2003
FLiPKicks's Avatar
got it installed. took me a while, i was trying to figure out how to make it turn on with the parking lights, and then blink when i turn. i followed the DIY. It said to tap it to the red wire on the parking light but the light is just constantly on. So later im going to buy relays and rewire it. I'll take pics when i wash the car. Only that section of the car is clean haha. thanx again
Old Oct 15, 2003
biohazard's Avatar
Question: When you cut the hole to fit the side marker, the metal is exposed, right? So then, what's to stop the car from rusting starting with that point? What can you use to protect that exposed metal that you cut? Curious, because I want to get side markers with the rubber gasket to protect, but I don't know if that's enough... Any ideas?
Old Oct 15, 2003
Krepoort's Avatar
I would say bare minimum would be to use a few coats of primer, some touch up paint, and wax.
-Kre
Old Oct 15, 2003
TeLLy's Avatar
My installer used a few coats of touchup paint on the exposed metal. Oh, and if you're gonna use a Dremel, pick up the diamond cutting wheel - it's GREAT. My buddy borrowed mine and used it for several more installs before having to replace it. Cuts through fender like butter.
Old Oct 15, 2003
FLiPKicks's Avatar
i put some primer and touch up paint on it. hopefully it wont rust. i used a reinforced cut off wheel. works wonders. just dont press when cutting. take your time.
Old Oct 16, 2003
biohazard's Avatar
What about "Rust-o-leum" paint? It's supposed to be an all weather paint... Shouldn't that work? Or is that too cheesy? Primer, then Rustoleum? I was thinking about buying rustoleum for some other projects, so I thought it might be convenient to use it for this. But I dunno...
Old Oct 16, 2003
FLiPKicks's Avatar
rustoleum should work. as long as the bare metal is covered, then ur fine. you should be rust free.
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
Misfit2613
Jul 30, 2015 09:49 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
