B series motor help
Old Oct 8, 2003
RoadRunner's Avatar
B series motor help
well i'm wantin to rebuild a motor so i can put it into an older civic or integra later this year. And i found a B16 block from a 95 del sol. the block has all the internal parts Crankshaft, bearings, pistons, rods, oil pan, so i bid on that block on ebay. and i was curious what else do i need to make the whole motor ... just a head right and valve cover. along with ecu, axles, motor mounts, wiring.
Old Oct 8, 2003
robbclark1's Avatar
Retired suspension supermod.
you will need the head/valve cover, ecu, motor mounts, wiring, TRANSMISSION!, and maybe some other parts like the intake and exhaust manifolds, fluid reseviors, etc. You may or may not need the axles, depending on what type of car you drop it into. If you are just making the engine, then all you should need is the block and the head, but that doesn't mean it will run. Is it a B16A3?
Old Oct 8, 2003
RoadRunner's Avatar
well i pretty much knew that just double checkin, what kind of head would work good with the B16 motor ?? i'm lookin to totally rebuild the motor with new internals, port and polish and turbo. I'm goin for speed with this car
Old Oct 8, 2003
robbclark1's Avatar
That would require mad work. Port, polish will help. You would want some better vavles and springs, and change the compression. If you are going turbo, talk to catalyst or boosted2k2 for info on how to change your motor to handle more boost. Or get honda-tech.com they should help you better.
Old Oct 9, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
You will also need a distributor and should probably look into a msd ignition due to the turbo setup.
Old Oct 9, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
If you building then you want
1) Pistons
2) Rods
3) Sleved block
4) Balanced crank shaft
5) Valves
6) Valve springs, retainers
7) Ignition system
8) Cam Shafts
9) Pullys
10) Cam Gears
11) ECU
12) Fuel Rail
13) Fuel pressure regulator
14) More stuff I cant think of
Good luck
~nick~
Old Oct 9, 2003
Cyko's Avatar
Cyko is an unknown quantity at this point
www.dh-racing.com drool......
Old Oct 9, 2003
RoadRunner's Avatar
that would be exactly what i wanna do, i have nothin to work on so i'm gonna rebuild a lil B16 motor, i know its not gonna be the fastest thing when i'm done. But its a project that me and my dad are gonna do, and when the motor's finished just drop that hoe into a 92 - 95 hatch. I'm still confused on what head i should get
Old Oct 9, 2003
RoadRunner's Avatar
that would be exactly what i wanna do, i have nothin to work on so i'm gonna rebuild a lil B16 motor, i know its not gonna be the fastest thing when i'm done. But its a project that me and my dad are gonna do, and when the motor's finished just drop that hoe into a 92 - 95 hatch. I'm still thinkin on what head i should get for the block ..
