do projector light come with harness?
Old Oct 7, 2003
HustleLikeMOFO's Avatar
HustleLikeMOFO is an unknown quantity at this point
i searched and i cannot find the asnwer to my particular question. i'm gonna order the projector headlights from rsversion.com and do they come ready to be just put in, do they have the place that i can plug the harness from my OEM headlights into? i know how to remove my OEM lights and stuff, i'm just not sure if the projectors will be as easy to put in as the OEMs are after i take them out. any help would be appreciated
Old Oct 7, 2003
Mr.Modify's Avatar
you need a harness? i thought you could use the OEM light harnesses? anyone?
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
plug and play..
wiring comes off of projectors and plugs into oem harness.
Old Oct 7, 2003
for the TYC ones, i think it uses all of your stock things..
for ones like this (wiht or wihtout the halo), i think it comes with a harness to convert it from an h4 hi/low to 2-h1 bulbs (1-hi, 1-low).. it all should be plug and play
Old Oct 7, 2003
like how easy is it to install the projectors once everything is taken apart? do i need to buy anythign additional that doesnt come with the projectors or is it just take out OEM and put projectors in with the same wiring and stuff? and do i need to cut or solder any wires? or is it just REALLY simple, same as takin OEMs out and putting OEMs back in?
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
maybe you should tell us which projectors you have bought and we'll give more details.
if you want, i have some TYC's for sale..
Old Oct 7, 2003
i really like the ones from RSVERSION.com, the clear/chrome ones with the blue r those TYCs?
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
nope those arent TYC
and the ones from RSVERSION are just plug and play like i said..
all you do is install the lights and just plug in the 2 wires BOOM!
done!
Old Oct 7, 2003
r the 2 wires i have to plug in, r they in some sort of harness or r they bare where i have to twist them?
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
you just plug the harness coming from the headlight to the factory harness..
thats it..
nothing else.
but if you get the ones with the HALO ring, like in the pic above, you have to wire alot of ****..
dont waste your time, get some good ones.. (TYC)
Old Oct 7, 2003
i feel like an a$$hole asking so many question, thanx a lot for answering neon. where can i get the TYCs chrome/clear?
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
i'd try ebay by clicking below:
http://cgi.ebay.com/ws/eBayISAPI.dll...category=33716
its the cheapest way..
sorry you dont want black, im trying to get rid of mine asap!
glad to help you tho
please keep posting if you need any other help!
try typing in: 01 civic TYC in the ebay search function..
you'll come up with millions of hits..
Old Oct 7, 2003
i'm kinda afraid to get stuff from ebay, i had a bad experience. i searched this site and i found www.thecivicstore.com and i'm pretty sure the projectrs on there are TYCs, is thecivicstore.com a safe place to order from?
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
nope use this then:
http://www.racerwheel.com/rt001205.html
Old Oct 7, 2003
so racerwheel is a safe site to order from rather then thecivicstore?
btw dude, u have no idea how much i appreciate ur help, thanx a lot
Old Oct 7, 2003
Macko's Avatar
Macko is an unknown quantity at this point
The halo projectors are simple.. just plug it in.. and for the ring you have 2 wires to deal with... just tap them into your parking lights or whatever you want to activate them
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
hey no problem..
racerwheel is a very safe/secure site to order from..
thats where i get some of my goodies from other than ebay..
good luck..
hit me up if you need anymore help!
Old Oct 7, 2003
again, thanx a lot of answering all my quesions neon, i will prolly get the TYCs from racerwheel.com then i'm gonna run peace
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
np..
hit me up via PM if you need anything else.
im always around!
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
and here's everything you need to know as far as installment, and bulbs, adjustment, everything!
always refer back to this thread or come to me if you need anything!!
1. Remove Bumper (see DIY)
2. Remove 4 Bolts All Around Headlight Housing
3. Remove Old Headlights
4. Install TYC's
5. Put 4 bolts back in
6. Plug in TYC Connector install Factory Connector
7. Turn on Lights and Test
8. If Working, Line up against a wall and adjust
9. See bottom of this page for adjustment procedures.
10. Put bumper back on
11. Go Cruise.
12. Learn to search the site
13. Thank me
14. Have Fun
** No cutting, splicing, opening, nothing!**
**BTW, Nice car man!**
How To Adjust:
**TO MOVE BEAM UP on the DRIVER-SIDE**
turn the outer(lower) screw counter-clock-wise
**TO MOVE BEAM UP on the PASSENGER-SIDE**
**TO MOVE BEAM TO THE RIGHT (towards the plate) on the DRIVER-SIDE**
turn the inner(upper) screw clock-wise
**TO MOVE BEAM TO THE LEFT (towards the plate) on the PASSENGER-SIDE**
(Thanks to falken for that DIY on previous thread)
I know you'll be sure to ask in the near future so check back for this if needed:
WHAT BULBS ARE IN THE PROJECTORS??
High Beams - H1
Low Beams - H1
Parking Lamp - 194
Turn Signal - 7443 (7440 work also)
Best Bulbs to Buy?
I have worked with MTEC, Eurolite, And Many Others and yes, every bulb will be bright just about, so its your choice of opinion..
MTEC are bright as hell and prolly the highest rating on the site.
Stock bulbs have worked for me perfectly fine, so its your decision..
Remember about laws against the bulbs..
The best way to go is get a H.I.D. Kit made by phillips or out of a lexus, bmw, or whatever..
Hope this helps..
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
klam
Nov 16, 2001 03:36 PM
