- Programable Siren?
- Center Pillars on Interior?
- SRS reset... WHY?
- how low can i go?
- Stock Head Unit Light Question
- how do you reset
- Interior power wire.
- maintenance lite blinks
- painting engine stuff.. need details
- Remote starter for 5-speed???
- fog lights
- Tap Into Fuse Box
- anyone have nos on a EX
- why spend $100 on Revo?
- Matrix Projectors
- APC Hood?
- does a bypass valve for an injen cai require cutting of the pipe?
- do i need orange bulbs?
- COMPUSTAR - Any problems ?
- Intakes for 2001 Civic LX??!?!?!?
- OBX Strut and Sprayers, NEED HELP!
- resonator...with or without???
- rims and calibrations
- ATTN: Delacapmos....
- Boxer sfc, vtec controller
- I cant find the DIY thread for shaving the emblems?
- 5w20 oil to thin for summer
- need Help installing AEM Air Bypass.....
- high pitched sound in my engine bay when car is not warmed up, what is it?
- OEM ALARM
- blown shocks?
- another question from the newbie
- wow this site Rules maybe you can help me?
- VCN 1000
- HEADER?
- How do i get the radio out of the dash?
- engine question.
- Rear Upper Strut Bar Problem!
- home made air freshener?
- honda oem alarm help
- Lower Grill DIY
- Nitrous in a Lx?
- New project/A Couple Questions
- Ground Contorls make noise
- AEM CAI Filter change??
- axle back system (exshaust)
- Pinstrip removal
- AC Reverse El Gauge Help!!
- umm water in exhaust
- Just installed DC Ceramic 4-1 Header...I can help out anybody if they got any questions!
- windshield lights
- Bulb Chart for projector lights
- removing stock "H" emblem
- Stock Dash!?
- Strobe Fuse
- Help with NOS Install
- Rear Suspension in 2002 vs. 2001
- 205/45/17's???
- Help me with tire choice plz
- reverse lights as turn signal?
- Free 10W 40 fully synthetic
- DIY: Upper Grill?
- I have a couple of questions...Please Answer !!
- z3-m3
- Bad Wobbling/Shimmy...
- Has anyone switch throttle bodies?
- V AFC Will work
- How to Customize Interior?
- Is there a way to wire out headlights to turn on when unlocking doors?
- ?? Help Car sits to low in rear??
- how much is it going tocost me to get my new muffler welded on?
- in need of CAI info
- DIY: Hyperblinker
- ATTN: Anyone with a service manual
- How to wire a power outlet...
- Cutting sheet metal?
- Question to my straight pipe brovaz!
- rear tail light does not work now, any help?
- Chamber question
- how to open tail light lens?
- Short throw adaptor or kit?
- MY CIVIC IS TOO SLOW! NEED WAYS OF MAKIING GO FASTER AND MORE HP!
- Rear dome light bulb solution!!!
- Is it really necessary to remove the reverse light switch when installing AEM CAI?
- removeing air vent trim
- Painting Stuff on the engine
- 30,000 mile service maintenance $400
- Changing Headlights
- dc sports tcs exhaust?????
- WeaponRcoilovers on LX?
- spring upgrade
- does oil really matter?
- Octane
- Another Solution for trunk rattle
- Camber Question.....?????
- clickin shift knob
- Hookup 747 landing lights to car
- headers for LX coupe
- DYI Taillights
- FIREBALL SPITING EXAUST
- Open Deck Question...
- cleaning injen filter...
- My buddy installed springs and now his wheels are golly poggled
- EX head and ECU
- Question about neons
- need help now!!!
- Lighted ignition ring swap
- Whats the Filter type for the 2k1civic sedan a/t
- flame throwin' exhaust
- where is INDIGLO DIY???
- BREATHER!!!!!!!
- difference between 6th gen EX & Si exterior
- I dont know how to describe this problem....
- Not addressed: AEM LX auto SRI
- Want to install rear sway bar, but will car fall apart?
- TURTLE: How did you remove the carpet on the door panels and put new on?
- lowering car - bad?
- Diff between HID and plasma blubs
- Intake Answers?
- 2k1 vs 2k2 indiglo
- ABS on 17s
- v-afc vs s-afc
- Fuel control settings
- Will AEM CAI for EX fit on an LX???
- how far will it go
- WARNING MAGNAFLOW
- Wiring HID help!
- Anyone do a DIY on lowering?
- I know it's stupid, but i want to know........
- Skinny OEM OIL Filter vs Fat OEM OIL Filter???
- I drained and refill transmission fluid.
- LED wiring ?
- Transferring rims from one car to another and painting rims
- Gauge Panel Remove?
- indiglo gauges hard to install ?
- Shaving emblems
- i was thinking......rear disc brake conversion..
- trunk lids
- How do I cut down my shifter?
- lowering
- Exhaust Installation
- Nitrous Install DIY for 2001 Civic EX
- Rims and tires
- Reverse Indiglo adhesive???
- Sparco Pedals
- Anyone ever install an alarm sys?
- Installing Rear Strut?
- Vapor line
- H emblem
- How do I shave my door handles and trunk???
- Replace fuel system?
- Seat belt tensioners
- severely bad hyperblinker problem!!
- coilovers vs. air bags or cylinders?
- 2k2 Civic Hyperflasher-searche forims, not find >_<
- help...want to purchase Spring
- Rotor and Brake Pad DIY Updated!
- Fuel return line
- SEMI ACCURATE WHEEL/TIRE WEIGHT
- Cat back exhaust
- Unable to find answers for shocks and camber kits after searching; Need questions answered...
- wheel colors for black ex
- Getting that piece out that in front of the gauges
- H & R Springs for EX 4dr?
- Painted Tails
- Flip Switch Mounting Spots
- exhaust question?
- header question!!
- What kind or motor oil is best
- air cylinders?
- Cold Air Intake in the Winter
- Shop in Houston...NEED TO KNOW........
- Who Has Painted Headlight Trims?
- Returnless Fuel system ?
- Cheapest rear camber solution yet.
- How much do your wheel/tire combo weigh?
- Automatic question???
- engine swap......
- lighting installation
- Washer LEDS - please help - basic questions
- Grey here's an oilchange diy for the the megathread
- Vtec controller?
- someone please HELP!!!!!!
- Heated Mirrors?
- Atte: ALLMAN
- Automatic Transmission Driving in D3 above 40mph and no redlining is it safe?
- Strobe ?
- people with 2k1 civic ex manual, please help!!!!!!!!!!!!!
- has anyone put a tach in middle of dash?
- Intake Question
- engine braking
- what RPM is fuel cut?
- Air bypass valve question
- When puttin altezzas in...
- Pro Shops
- Atten: Grey
- Online VIN checker, without the Calculus involved.
- RSX chassis parts
- Is This Bad?...some advice...sorta new
- The intake makes me think VTEC
- Nos setup
- Injen CAI intake instructions figure #8 and step #5 making a 3" opening?
- gauage kit
- gauges
- Intsalling short ram intake
- 7th Gen Model Code?
- SPEED LIMITER !!!!!??????!!!!please help!!!!!
- cruise control?
- Removing Resonator
- Service Manual?
- Auto Transmission Hack!
- How did turtle make his trunk do that.
- Good news, aftermarket oil filter magnet not needed.
- Rims
- The noise from the engine compartment after shutdown.
- anyone paint their tweeter pods?
- maybe just maybe ????
- sideskirts
- Interior Neon Wiring
- Need head work
- why only 120
- Question about synthetic blends oil.
- ???rapidflash??????
- fog in altezza...
- Lowering car?
- NOS
- any one know what color wire is for the tach
- HID Ballasts
- diy springs?
- Automatic Shiftknob
- how the F@#k do i get this off
- Torque?
- 40 series or 45 ???
- lower grill help?
- port & polish piston & rods
- Neon lights in the interior
- for those of you that DIY oil change... what about other maint.?
- Question on Rims with Eibach Pro-Kit....
- Will rims off a....
- Fog Light Switch Wiring Diagram
- Someone with the honda service manuel =)
- Headlight aim adjustment...
- Have you Advanced the Timing?
- B18C5 WILL BE DONE
- wanna custome make cai intake and other goodie!!!!!!!!!!!!!
- Removing doors w/ roll down windows
- Painting Parts?
- Bypass valve and an Injen CAI intake any other way besides cutting the pipe??
- Shaving off stock "Tint dots"
