removeing air vent trim
Old Feb 13, 2002
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
i wanted to remove the air vent trim pieces so i could paint them. i did a search and someone said to pry the air vents off. won't this make the air vents loose when i put them back? Also, has someone removed the air vent trims another way?
Old Feb 13, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
All you have to do is pull it straight off......DON'T PRY IT OFF !! You will warp the vinyl that surrounds the vent and it will
look like crap. Just get a good hold of the vent and pull that thing off......you will think you broke it when it comes off, but you won't !!
Old Feb 13, 2002
Chuck94527's Avatar
Chuck94527 is an unknown quantity at this point
where would you suggest grabbing hold of it to pull it off? it doesn't seem like there's any place that you could get a good grip.
Old Feb 13, 2002
eProdigy's Avatar
eProdigy is an unknown quantity at this point
its actually really easy, i just got a really tiny screw driver, the kind they use to repair eye glasses, then put a rag over it, and started at the bottom and got it up about 1/4 an inch, then put the fingers under it and pulled. you will see it just pops right out.
Old Feb 13, 2002
C2i0v0i1C's Avatar
SuperMODrizd
unscrew the two screws in the bottom, put ur thumbs in the tray under the cd player or whatever u might have, push the top two air vents down place the rest of ur fingers in there and then pull. it worked like a charm for me more than once
Old Feb 13, 2002
bottlefed's Avatar
bottlefed is an unknown quantity at this point
UM, c2i0v0i1c, i he wasn't talking about that. he is talking about the small vents on the side
Old Feb 14, 2002
pimpedcivic's Avatar
pimpedcivic is an unknown quantity at this point
the way i got mine out....
if you push the vent so its aiming all the way down you can put your fingers inside the vent thing just grab ahold and pull out
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
crowtoo
May 11, 2015 06:50 PM
Ronin
Apr 18, 2002 10:14 PM
CivicHX01
Nov 2, 2001 08:49 PM
