Getting that piece out that in front of the gauges
Old Feb 7, 2002
Gengar's Avatar
Gengar is an unknown quantity at this point
OK. I understand that after you remove the 2 screws in the top, you supposedly just pull it out. I tried this yesterday to no avail. How hard do you have to pull on the damn thing? I seriously thought I was gonna break it. It seems to be stuck right above the steering wheel. I can get it out at the top and down the sides. I'm sure others have taken this out, but jeez. Mine's really in there good. Can anyone recommend a tool or something? Maybe one of them trim panel popper things?
Old Feb 7, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
you just gotta have faith in your self and PULL. it helps a bit if you take off the steering column housing. good luck
Old Feb 7, 2002
pounds's Avatar
pounds is an unknown quantity at this point
there are two clips on the bottom by the stearing collum.....if you pull up on that then its a bit easier...if your brave enough you can try and wedge a flat head screwdriver in there and push the clip out....but be careful cause you can damage your interior or break the clip
good luck
Old Feb 7, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Here is a link to another thread where I gave some instructions...
If you have further questions, PM me and I'll help you out... Good Luck.
wcodyd
Exterior
Jun 22, 2015 11:24 PM
beachglass
Jun 1, 2015 08:28 PM
werdnahall
May 17, 2015 11:37 AM
cooldan1
Apr 23, 2015 10:49 AM
CivicHX01
Nov 2, 2001 08:49 PM
