Sparco Pedals
Old Feb 8, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
Sparco Pedals
I'm looking into buying the sparco pedals for the auto (see link) - This Is The Link
Can anybody tell me how these will need to be installed before I buy. I know at least a couple of you have sparco pedals so maybe you can tell me what's involved.
Thanks
Old Feb 8, 2002
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
real easy get out your drill and start making some holes in your car[IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 8, 2002
Redsands's Avatar
Redsands is an unknown quantity at this point
Just what swifty said, just a forwarning though, drilling aint easy down below your dash. Have some patience and a sharp drill bit.
Redsands
Old Feb 8, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Yeah, and when your done, dont touch the pedals for at least half an hour. My brother got burned on the hand real bad when we were putting mine in.
Old Feb 8, 2002
so does the rubber piece come off, you drill holes in the pedal itself and bolt these on?
Old Feb 8, 2002
LOWBOY's Avatar
Yes, the rubber pieces come off. Line up your pedal how you want it and fill in the two overlaying holes w/ something you can see so you know where to drill. When your done, wait and bolt them in from the rear. Oh yeah, make sure you have something underneath the pedals so they dont move.
Old Feb 9, 2002
Swifty's Avatar
first take off the rubber pedal, then wrap the metal in some masking tape, and use a felt pen to mark the holes on the pedal......it's much easier to see this way.....also if you have some spring loaded clamps use these to make sure the pedals are in the right place......if you used a good drill bit the pedal should not heat up too much so give it a miniute or two to cool after drilling.....Remember measure twice and drill once!!!!!!
Old Feb 9, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
looks good
i like it a lot
Old Feb 9, 2002
SQCivic's Avatar
SQCivic is an unknown quantity at this point
The rubber boots come off the gas & clutch, but not the accelerator. Do you just drill thru the rubber or is there some way to get it off?
Old Feb 9, 2002
new2civics's Avatar
new2civics is an unknown quantity at this point
The drill goes through the Accelarater real easy... Its like drilling through cardboard.... But the clutch and brake are hard..... Take your time with them
mistahlorax13
21
Nov 18, 2015 12:47 PM
sesi
Oct 1, 2015 02:03 PM
juicetayne
Sep 30, 2015 11:02 AM
speedlever
Sep 24, 2015 07:18 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
