ABS on 17s
Old Feb 11, 2002
zackde's Avatar
zackde is an unknown quantity at this point
ABS on 17s
guys........
if i will replace my stocks w/ 17s will it have any effect on my ABS??
Old Feb 11, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
no, it would not. if it did, i surely doubt not many members would have gotten them
Old Feb 11, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
It will not affect your ABS at all. In fact, when plus sizing, you can actually stop faster than you could with the stock size.
Or is it they other way around ?? Hmmm....I think stop times are better with 17"s versus 14" or 15" wheels and tires !!
Old Feb 11, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Yeah, I think antidote is right. You'll stop faster because of the larger contact patch from having wider tires, which causes more friction...
Old Feb 11, 2002
thx1138's Avatar
thx1138 is an unknown quantity at this point
.....and degrades your mileage. Only a little though. Has anyone with 17's noticed a real change in fuel economy ? Or top speed for that matter.
Old Feb 11, 2002
antidote11's Avatar
Not only does it stop you faster because of the contact patch, but also since it is a larger wheel, it is actually rotating slower than
a wheel 2" smaller at the same speeds....did that make sense ? : )
Old Feb 11, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The only consideration you have to pay attention to with ABS is keeping ALL the tires and rims the same size! Basically, the ABS is determining if one tire is moving at a different speed. Say you had the rear tires a bit bigger, then the ABS would always think the fronts were moving faster.
Plus sizing is not an issue, and if they are all the same size, you can rotate them to last a bit longer.
h4ldol
Apr 24, 2017 08:16 PM
viperGTS
Jul 27, 2015 08:40 PM
turboslug
Oct 15, 2002 09:49 PM
RedDragon333
17
May 23, 2002 11:55 PM
Unomyname
Jan 31, 2002 07:01 PM
