I drained and refill transmission fluid.
Old Feb 9, 2002
01LX's Avatar
01LX is an unknown quantity at this point
The fluid already turned dark brown, like fresh brewed coffee, a little bit transparent still. I also found a lot of debris on the plug magnet, already. I didn't expect to find that much metal filling and gunk, especially at 16,000, thought the magnet is not very strong.
All-in-all, it was good that I did it and I'll continue doing it. I'm gonna be changing tranny fluid every 15k. Only cost $3.92 a quart of ATF-Z1 fluid, and took 2.5 qts.
What's in your automatic transmission?
Old Feb 9, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
wow, wouldnt expect it to be that bad so soon in a new car
Old Feb 9, 2002
mohawkboom's Avatar
How Often do you hear that wonderful Gear grinding sound [IMG]i/expressions/face-icon-small-smile.gif[/IMG]... That's your dog teeth grinding on the gears. he he.. if it's an auto though you have some serious problems..
Old Feb 10, 2002
Grey's Avatar
DIY King
I think I'll do that too when I hit 15,000 miles. Right now I'm only at 6,000. What about the plug magnet? Which part is that? The bolt that you use to drain the transmition fluid out of?
Old Feb 10, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
for a plug magnet you can use anything. just take a magnet and stick it on the plug. i have one there and also on my oil filter. it cost like $7 total.
Old Feb 10, 2002
01LX's Avatar
Grey: I would have thought you'd have more miles than 6k. But anyhow, it's one year for me this month. If you don't know, the magnet is on the other end of the plug, about 1 inch in length. I know you have a fetish with this magnet thing. hehe Don't be ashamed, so am I. haha. Only wished the oil plug had one also, but like i said before, the OEM oil filter has one already. I'll be sure to open one up next oil change.
Mohok: From experience, I believe it's normal wear. But you see, I did a tranny fluid change on my 95 at around 45k, after the dealer did it (I believe) at around 30k.
I started to do maintenance myself on the 95 after the first couple of three visits to the dealer, 1st at 3750, then 11750, 15k, and 30k, it started costing too much then I quit going and did stuff myself, though I'd do oil changes myself.
Old Feb 10, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Damn, how many miles are on your car. That doesnt need to be done until 60k miles I thought. do you drive your car really hard or what?
Old Feb 10, 2002
deception420's Avatar
deception420 is an unknown quantity at this point
uh lowboy... go ahead and read the first post again, it clearly states the number of miles
Old Feb 10, 2002
avenger's Avatar
avenger is an unknown quantity at this point
did you just assume it was bad or did you actually smell the fluid? Also, that amound of metal is uncommon, you should take it to the dealer asap.
Old Feb 10, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Maybe i should check/flush mine..... seein how i do have 24,000 miles on mine!!!!
Old Feb 11, 2002
01LX's Avatar
For anybody who wants to do it, please do so at or around 15k. Then we can compare the results. I kinda think it is uncommon.[IMG]i/expressions/face-icon-small-frown.gif[/IMG] But I have no standard to compare this to. If I do take it to the dealer for service, what am I going to say?[IMG]i/expressions/face-icon-small-confused.gif[/IMG] But you know what, and I've posted this question before, I feel when I shift to D, it double engages, something with the torque converter may be whacked. I wish I could have taken a pic of it, dammit, a relatively good digicam gone to waste![IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Here's the DIY for changing your tranny fluid.
1) 3/8" ratchet, and go under your car, no jacking req'd. Look for a square 3/8" flange bolt and loosen. It was difficult for me, I actually broke the head of the MIT ratchet, (Made In Taiwan). POS. I asked a mechanic to loosen it for me.
2) Unscrew bolt and let it drain out.
3) Jack the car up from the opposite end to drain more.
4) Clean debris from magnet portion and rescrew bolt.
5) Fill 2.5 quarts of ATF-Z1, ONLY!
Congrats, your done!
Let me know your results, and your opinions, plz!
Old Feb 11, 2002
avenger's Avatar
everyone with an auto should smell their atf at least once a month. You can diagnose a problem by the smell. If the fluid smells burnt, its time to take a peek [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 11, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
i don't have an auto so i don't know, but with all the other autos i had, they had a filter that was either replaced or cleaned. civic doesn't have one?
Old Feb 19, 2002
Voiceofid's Avatar
End Bringer
planning to do a transmission flush within my next 2 oil changes
Old Feb 20, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
should have seen the tranny fluid on my old 82 Ford Fairmont. now that was nasty. hehe.
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
mcollins
Electrical
Jul 27, 2015 10:59 PM
Q-Bert
Jul 19, 2015 09:09 PM
Jul 12, 2015 11:54 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
