Lower Grill DIY
Old Feb 17, 2002
skier167's Avatar
skier167 is an unknown quantity at this point
Lower Grill DIY
Ok I"ve done the search and I looked under DIY but the lower grill one is gone. Does anyone know how to do it......I can pretty much figure out myself how to mount it but where do you get the material for the grill and what is it called.......I went to home depot last night but didn't see anything really
Old Feb 17, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
I'm doing the same thing right now... well I have it installed, but I still need to fine tune the alignment etc.
The material is found at home depot, but you have to look hard for it.
The stuff is in the same isle as the quick dry cement and chicken wire. Both Home depots I've been in, it's in the same location. Very last isle on the lumber side.
The sheet is like $2.98 and you get an 8'x2' section, more than enuf.
I was going to make a DIY but basically you just need to remove the front bumper, cut out a section to fit. bend it at some places and secure it to the bumper. I drilled small holes and wrapped wire around it.
It looks pretty nice, but if I do it again, it might look better.
Good luck.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
speedlever
Sep 24, 2015 07:18 PM
