Cheapest rear camber solution yet.
Old Feb 6, 2002
2k2civic's Avatar
I read this somewhere, can't remember where though. But all you need to fix the camber on the rear wheels is two bolts that are the same size, but a tiny bit longer than the stock bolts holding the upper control arm, washers for that size bolt, and thread locking stuff. You just replace the stock bolts with the longer ones and add the washers to space the upper arm from where it attaches and use the thread lock stuff to keep the screw from getting loose.
Old Feb 6, 2002
pounds's Avatar
pounds is an unknown quantity at this point
you got any proof of this??
Old Feb 6, 2002
blouisgod's Avatar
Life Begins > 6800rpms
find that site!
Old Feb 6, 2002
2k2civic's Avatar
It was at jdmfan.com - this is a direct link to the article.
It does say it's for 6th gen civics, but I've done a little work on the suspension of my own car and can tell you that it would still work for the 7th gens.
Old Feb 6, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Basically all you do is use washer from the hardware store to change the camber angle... It sounds like a really cheap DIY to me and sounds reasonable..
Old Feb 6, 2002
silverhx's Avatar
silverhx is an unknown quantity at this point
cool, have you or any one else tried it on a 7 gen? keep us posted!
Old Feb 6, 2002
VNlilMAN's Avatar
The Standard One
uh... when you lower the car doesnt the camber have to be like this / \ and not like this \ / ? cause by adding the washers it makes it like \ /
Old Feb 6, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
That would work. But the reason we buy "real" camber kits is cause its able to easily be adjusted. I guess if you got some springs, then you could set you camber and forget it, but for me. with coilovers, it is easier to adjust camber with the Ingalls(or Eibach) kit.
Old Feb 6, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
its a welfare camber kit, you could just add/remove washers to adjust for ride height[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 6, 2002
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
my tech told me it wont work cause our rear is deferent they already tried and no luck!! sorry to burst a bubble guys
Old Feb 9, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
our rear control arm setup is completly different....you must buy the complete rear trailing arm
specprod makes them dirt cheap
contact torn active...
you can get the ENTIRE camber kit, front and rear for around 100 bucks!
peace
Old Feb 9, 2002
huyqvu's Avatar
huyqvu is an unknown quantity at this point
i already tried the washer thing, doesnt work. ended getting a set of ingalls.
GolNat
Jan 12, 2021 09:06 PM
Wolfcamp
Aug 14, 2015 08:52 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
