PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Zex Kit
  2. Auto Civic Performance HELP
  3. Aem Pullies (searched for 2 hours)
  4. rsx sway and dc tcs
  5. SRS light on after RSX-S seats swapped...
  6. windows
  7. Cold air intake help
  8. Water Temp gauge
  9. SPOLIER INSTALL?????
  10. Muffler
  11. taken care of
  12. another O2 simulator
  13. Im An Idiot!!!!!!
  14. Reseting SRS Light.....
  15. v6 accord engine
  16. good cam gear yet????
  17. Body kit installation question
  18. Vtec cover
  19. Interior Painting
  20. Wiring harness
  21. day time running lights???
  22. 3rd brake light
  23. CAI rubbing strut bar
  24. Will an rsx akle-back bolt up???
  25. diy a/c control relocate
  26. Ground Wire?
  27. Can i change oil filter without changing oil
  28. VTEC button?
  29. install flywheel
  30. fuel system info.
  31. Yet Another HID question...
  32. Gauge Cluster Wiring
  33. Dose SI 03 rear seat Fit our 7thgen???
  34. Apexi V-AFC II and Non-VTEC?
  35. wiring rear turn signal lights to stay on
  36. Air/Fuel guage install...HELP!?!?!?
  37. crank pulley !!!!!
  38. Tuning K20 Engine?
  39. 02 coupe EX front bumper OEM
  40. Fans on a switch?
  41. RSX 6 spd tranny in 7thgen?
  42. radiator fans wont come on
  43. installing new carpet
  44. has anyone painted the OEM mirrors?!?
  45. Sound?>_<
  46. TYC Projectors Question (HID)
  47. Warranty Blues
  48. License Lamp Switch?
  49. SF kit- vafc settings?
  50. any internals out for our cars yet ?
  51. Si/SiR side panel swap
  52. removal of rear seats
  53. How do i take off side door panel?
  54. age old question
  55. DIY: Techometer?
  56. transmission guru's
  57. Stock Headlights
  58. DIY Brake Drums?
  59. center console removal for automatic
  60. Eurolite underdody neons
  61. power windows
  62. lower grill removal DIY
  63. What is a B-Pipe?
  64. Need Help Asap Vacuum Guage
  65. Do you believe that this will work in our EX's.....?
  66. 02 Si/Sir Seats in a 7th Gen Civic?
  67. Red Line
  68. MOMO Steel Wings Update
  69. DIY sedan door leather insert+cheap deadening
  70. k20 help
  71. Good Place to Ground Wire??
  72. no more color change in tyc's after mtecs
  73. Relocating the battery
  74. Compression ratio? what is that?
  75. Anyone relocate their ignition key location?
  76. sleeving the D17??
  77. 2001 Non-VTEC Any Potiential
  78. spark plugs Q
  79. high wattaged bulbs
  80. MOMO Steel Wings
  81. throttle body rattling
  82. Removing stock headunit (read DIY)
  83. Halo-Ring Issues
  84. stock guage cluster wiring.
  85. HID conversion
  86. HID in stock
  87. how can i make it not rattle...
  88. Door Lock Question?
  89. Tach not lighting up!
  90. Removing the front grill.
  91. motor mounts
  92. Momo Diy Installs
  93. Help my brother out with a question
  94. i need 03 civic info
  95. How do you paint body parts?
  96. Clear TYC Projections
  97. anyone have a diy for adjusting valves and replacing the timing belt?
  98. **Need Help** Oil Temp Sensor
  99. How does your exhaust fit under your rear body kit/lip? ie: xenon..
  100. M3 Mirror Question Having to do with Stock bolts!!!
  101. exhaust
  102. WTF...i can't get the a/f gauge to work
  103. headlight harness
  104. is it possible to mold...
  105. if we got intake manifolds...
  106. Tachometer help!
  107. Best/easiest way to jack car for exhaust install?
  108. Interior paint to match the dash
  109. Need a little help
  110. DIY fiberglass instructions w/pics
  111. Cold Car???????
  112. Tech engine question
  113. exhaust question
  114. Resealing headlights
  115. do pullies really do anything ?
  116. Lightest Material for Sub Box?
  117. rewired taillamps??
  118. How much would a VTEC head cost
  119. How do you get to the crank shaft pulley?
  120. Revo Short Shifter for SI 2000?
  121. Top Speed Header/High Flow Cat Install TODAY!!
  122. o2 sim.
  123. How much to paint?
  124. Custom Hood Scoop?
  125. Engine Reboring?
  126. Help!! Melting bumper!! (pics)
  127. Rusty Sparkplug Sleeve = ?
  128. ECU OBD 2 Command Question...
  129. Somebody please help (installing pedals)
  130. touch up paint
  131. guage cluster swap for dx
  132. My emblem fell off
  133. O2 Sim = Lose or Regain Power???
  134. I know someone has probably asked this a 100 times but I'm new to the honda world
  135. Hydraulic Clutch Removal?
  136. ViS Vader Hood......
  137. where is the belt tensioner
  138. Blinker Speed Question
  139. stock B-series motor in an LS integra
  140. confusing about engine oil
  141. Can I take this apart??
  142. more hood questions
  143. How do I.....
  144. Octane Front Q's???
  145. Cruise Control not controlin?
  146. Differential Dimensions
  147. Any B series transplants
  148. o2 Simulator?
  149. What kinda engine is the new 2k3 civic coupe?
  150. Oil Pressure Gauge
  151. Tsunami T2001 front grill question
  152. Sanding
  153. help with tucking fender lip
  154. transmission
  155. Increased Exhaust Piping (2.25")
  156. Angel eye projector problem
  157. Going to install the Top Speed Header w/High Flow Cat!
  158. how to make fiberglass
  159. TRans Question
  160. Time frame for clearing headlights
  161. cam gear
  162. quick question about new bulb headlight install
  163. Seat brackets???
  164. Has anyone here replaced an alt before?
  165. K20 engine
  166. Mobil 1 Prevents Engine Wear?????
  167. Cut off
  168. downpipes
  169. For those with after market steering wheel.................HELP!!
  170. got my new civic finally..
  171. Throttle Body Boring?
  172. outside lense of headlight..
  173. Headers
  174. ECU signal for fuel and temp...?
  175. Installin Tailights
  176. is the inner fender plastic stuff needed?
  177. ECU OBD Location?
  178. Better refrigerant for your AC
  179. how many HP do u lose with A/C on?!?
  180. torque converter
  181. Help Find these Parts
  182. What Aftermarket clutch u got?
  183. Bumper Removal
  184. m3 side mirrors...
  185. Can I change the shifter on the auto?
  186. Does bigger piping increse or decrease the hp in 02 lx?
  187. What is the redline of a D17.....
  188. car problem HELP!!
  189. automatic transmission shift point changeer thing
  190. what's a brake booster?
  191. fogging
  192. Help w/ TYC Projectors
  193. heatshield
  194. Need help finding the right main bearing....
  195. Opening up a Tanabe a lil' bit
  196. Help My Car Wont Start!
  197. K20A vs. K20A2 --> (differences?)
  198. oil
  199. Connecting Rods
  200. DIY for Revo SS
  201. VTEC conversion
  202. Where can I buy a SCS Service Connector?
  203. hood pins needed?
  204. question about watershield layer
  205. engine questions..(noob questions)
  206. Blue LED Gauge Swap complete
  207. JB Weld = Good
  208. Should I get bigger piping for my exhaust, or get cams and pulleys?
  209. sliding ragtop
  210. DIY Rear Bumper
  211. zc?
  212. friend put a dent in my hood
  213. digital rpm and speedo led readout
  214. bulb - headlight
  215. Aem Pulleys does anybody have a problem with them ?
  216. Removing Interior Roof Panel?
  217. NEED HELP!!!!! S-AFC and GEAR PROBLEM
  218. need help on revo short shifter ASAP
  219. evo exhaust and progress rear sway? need help!!
  220. Help with Razo Up shift indicator. What setting to put at?
  221. Vibration
  222. alternating parking and turn signal bulbs
  223. Anyone know?
  224. help! paint my oem headlights
  225. side airbag light w/ racing seats
  226. **help**projectors might be broken.
  227. Needle removal..
  228. What is the voltage range of..
  229. Skeleton Key?
  230. Made my own ground kit! Woohoo! W/pics...
  231. Exhaust Hitting Sway Bar, How To Fix????
  232. diy : throttle plate adjustment
  233. DIY : air filter replacment
  234. Head Torque Specs Plzzzzzzzzzzzz!!!
  235. For Members Already Done With K20 Swap
  236. Subwoffer question
  237. what is the use of a resonator???
  238. hid install
  239. HELP with Tail Light / Rear Bumper
  240. how do u get your headlights out
  241. head and tailight problem..
  242. Installing new seats, need help...............
  243. Injen Installation HELP ME
  244. RSX 5spd Shift Mechanism
  245. Has Anybody opened up their taillight assembly?
  246. standalone
  247. univeral muffler choices
  248. Car shakes when A/C on
  249. Help!!!!
  250. ACT Clutch Problem
