Somebody please help (installing pedals)
Old Aug 1, 2003
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
Ok I probably sound like an idiot....I bought a set of Ractive pedals, nice chrome ones...anyways, I installed the clutch and brake fine, but I can't install the gas pedal......somebody please give me some direction on how to...
thanx
Old Aug 1, 2003
gotti's Avatar
Read the directions, give us some detail on what they say to do and we can probably help you. At least give us a pic or 2 to work with
Old Aug 1, 2003
NCStyle's Avatar
Lax Playa
NCStyle is an unknown quantity at this point
yeah i could probably tell u the problem if you could show us a pic of the pedal or tell us the instructions, somethin... haha
Old Aug 1, 2003
R3DL1N3's Avatar
you have to drill a hole in the gas. then connect the side things like you did on the other 2.
Old Aug 2, 2003
djspot's Avatar
fuk tha man!
that's the thing fellas no instructions, but yeah I took some pics....this is what I got to work with.....
2 long screws, 2 small screws...a long soft aluminum bracket and small something else...and a double sided 3m type sticky tape....
here are some pics...
hope you guys can help.....
Old Aug 2, 2003
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
drill that black thing on the back of the ractive pedal to the gas pedal. then simply connect it to the ractive pedal using the 4 outer connectors
Old Dec 29, 2009
CoupedUp04's Avatar
CoupedUp04 is an unknown quantity at this point
Re: Somebody please help (installing pedals)
Oh thank god I found this thread. I have the SAME exact problem. The clutch and brake are easy, but the gas pedal is impossible to figure out. The instructions on the back have three different gas pedals and none of them match the one in my set. I'm hoping to not have to drill into the original pedal. Is there any way to do this?
It seems like there has to be a way. I mean, why would they give you all this other hardware without having to use it?
I rigged it all up so that bracket just wraps around the pedal, but it could easily slide off. I definitely need something more secure...
bump for more info!
Old Dec 30, 2009
TRIZ's Avatar
The clutch and break pedals are metal once you remove the rubber outter portion. I drilled right into these and used rivets to secure my type-r pedals. As for the accelerator pedal, its plastic without any removable cover. I drilled into this one too and I believe I used flathead screws instead to keep it in there as opposed to rivets.
I assume this will answer your question. If not, post up what kind of hardware it came with and a shot of the pedal.
Trennytrent
Jul 10, 2015 09:01 PM
fvckbg
Jul 7, 2015 07:08 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
