ECU signal for fuel and temp...?
Old Jul 29, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Question ECU signal for fuel and temp...?
I have searched and I can't seem to find this info.
I need to get a bit of information about the ECU or even where I can find this info.
I am looking for a place in the car (was hoping ECU) that I can tap into to get the signal that tracks the fuel level and the temp level of the car. That is, I want to get the signal that is going to the 2 guages in the cluster that tells these 2 bits of information.
Anyone know where I can find this signal? And if I can, are they a voltage or digital signal from a sensor somewhere?
Any suggestions?
Old Jul 30, 2003
HP's Avatar
HP
HP is an unknown quantity at this point
The temp can be found on the ECU RED/WHT wire on the B connector Pin 8
And also on the Multiplex unit
Anyway its a voltage between 0.1-4.8V depending on the temperature
The Fuel level indicator signal can be found at least behind the gauges YEL/BLK wire on the A connector Pin 8
The resistance of the pot in the FGSU and positions on the gauges are the following
F: 11-13 1/2: 68.5-74.5 LOW: 113.4-128 E: 130-132
The FGSU is fed with 5-8V so you do the math on the voltage level...
Old Jul 30, 2003
Sivion's Avatar
Resident Tough Guy
Exclamation Awesome!
Hey thanks for the reply. It's exactly what I needed.
Old Jul 30, 2003
Sivion's Avatar
Resident Tough Guy
Oh yeah..
For both the connectors (Temp and Fuel) are you referring to the connectors on the ECU pin layout? Or is the fuel "A" connector referring to the connector going to the guage cluster itself?
Thanks man
Old Jul 31, 2003
HP's Avatar
HP
Yeah, the fuel one is on the gauge cluster and it's A3, and not A8.. sorry
the temp is on the ECU B8
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
McD
Apr 22, 2015 05:28 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
JoeB16
61
Oct 16, 2003 07:58 PM
