v6 accord engine
Old Aug 11, 2003
BatMan's Avatar
BatMan is an unknown quantity at this point
v6 accord engine
would it be possible to fit a 2003 v6 accord engine in a civic???
Old Aug 11, 2003
civicvtec1ps's Avatar
Search and Learn
im sure its "possible" . anything is possible right ? with shiet load of money.
Old Aug 13, 2003
erica02civicCPE's Avatar
erica02civicCPE is an unknown quantity at this point
good luck finding a 03 v6accord engine
Old Aug 13, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
To put a J engine in a Civic? I dunno... that thing takes up a lot of space. I bet it's heavy as hell, too. The one with the 6-speed carries the Accord across the quarter in 14 1/2 secs. You could seriously throw the weight distribution off if you pulled off putting a 3.0 V6 in a lil EM2.
Old Aug 13, 2003
al4t1gbundy's Avatar
al4t1gbundy is an unknown quantity at this point
i dont think it's possible squeezing that v6 into a civic's engine bay w/o some major major work. you can barely squeeze the k20 in and thats 1.0L and 2 cylinders less than a v6 accord
Old Aug 13, 2003
All Eyes On Z
Bad logic.
If you haven't noticed by now, the K20 engines were actually meant for the 7th Gen Civic's engine bay.
Old Aug 13, 2003
Green Civic's Avatar
If some one put a K24 engine into a civic, the weight distribution will be off. Even with a K20 engine, the weight is off. But of course the K20 engine does not weigh nearly the amout the K24 does. Its the same if you put a 94-97 accord engine in a 92-95 civic. Of course the prelude engine fits, but have you looked in the engine bay. The H22 takes up a little less room than a F20? (accord engine). Now a 6th gen civic has to shave and modify the engine bay for a H22 to fit, and then it barely fits. Its basically the same logic.
Old Aug 13, 2003
DUGMAN's Avatar
DUGMAN is an unknown quantity at this point
Could you not get the same power from the K20 then from the accords V-6 just as some minor bolt ons????
Old Aug 13, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Anything can be done with money. But it will be expensive, throw off your weight ratio. And it will be an engine that has less parts out for it than a D series motor. If you are swapping an engine its because you want to swap it for a more popular more powerful motor...
Old Aug 13, 2003
as far as HP wise the k20 can accomplish the v6 engine..but one very important thing is the TORQUE....it'lll be very hard to squeeze some torque w/ minor bolt ons...but then again the weight issue comes to play
bokogabe
May 21, 2015 09:27 PM
usajags84
May 10, 2015 08:11 AM
meels808
Jan 8, 2002 10:24 AM
supercivic01
South
Nov 30, 2001 11:27 AM
htowncivicEX
Nov 13, 2001 04:30 PM
