head and tailight problem..
Old Jul 24, 2003
civic12's Avatar
civic12 is an unknown quantity at this point
ok..i just recently cleared my headlights....but while i was takin apart my headlight i pulled a little too hard and broke my blinker bulb a little bit..it wasnt the bulb itself, but the part that plugs into the wire part...ok..didnt think much of it...so went and bought 2 new blinker bulbs...ok..i replaced it and put my headlights back in and plugged up all the lights..ok...the blinker bulb comes on...but..it doesnt blink...but the thing that i thought was really strange was that when i turn my blinker on on this certain side the blinker blinks like 5X faster than the other side..one side of my tailights blinks normal and the other side blinks really fast...i dont understand....but i thought..well..maybe ill replace the front blinker bulb again so when i took out the blinker bulb the same peice broke off the bulb as did before...can someone help me?..
Old Jul 24, 2003
R3DL1N3's Avatar
must have done a hyper blinker or whatever on accident
Old Jul 24, 2003
bamb00's Avatar
When I replaced my stock turn bulb, the driver side didnt' blink but from inside the car it's blinking 40 times faster, so is the driver side tail light turn bulb, I popped the hood and played around with the socket and then the crazy blink just went back to normal. I would just look at the socket and make sure nothing is really out of place, and maybe flip the bulb itself around, that's what I did, too. Good luck.
Old Jul 24, 2003
civic12's Avatar
i dont understand..my front blinker light comes on..but it doesnt blink..but when i turn the blinker on...the tailight blinks twice as fast...
Old Jul 24, 2003
bamb00's Avatar
Same thing happened to me. Just play around with the socket and the bulb, I didn't have hyper blinker crap.
I think it's because the metal parts are not touching properly. Maybe you've bent the metal strips on the bulb.
Old Jul 24, 2003
civic12's Avatar
well..when i replaced my stock blinker bulb it didnt work...so..i took out the blinker bulb and pieces of it broke off just like they did when i broke my very 1st bulb..but i put it back in for the heck of it to see if it would work and it did...the light still comes on but there is no blinking in the headlight...and the tailight still blinks faster
Old Jul 24, 2003
bamb00's Avatar
try switching passenger and driver's side bulbs, I would say almost for sure it's the bulb's problem, unless you severely damaged the socket. Just play around with the bulb, that's what I would do.
Old Jul 24, 2003
civic12's Avatar
ok..i just tried foolin around with the bulb...switched it around and stuff...still no blinking...
Old Jul 24, 2003
bamb00's Avatar
Sorry dude I am out of ideas, try compare the two sockets and try to find the differences.
Old Jul 24, 2003
civic12's Avatar
you know where i could jsut buy another socket? im sure they wouldnt be that expenisve...i hope lol...
Old Jul 24, 2003
wonderz's Avatar
wonderz is on a distinguished road
hm...can you even buy light bulb sockets? also your "hyper blink" problem is due to the problem u have with your front blinkers. They are just wired that way, when any one burned out or something, some other one will go into "hyper mode".
In another words, when you fix your front blinkers, your tail blinkers will go back to normal.
Old Jul 24, 2003
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
my guess is your problem is with the metal ends on the bulb lining up correctly in your socket. Just like everyone else said, just try to mess around with geting that bulb in the socket just right. And like wonderz said, the hyper blinker mode is due to a change in the resistance of the circuit from the front blinker not working, it'll be fine once its fixed
Old Jul 24, 2003
bamb00's Avatar
Yes, I think the reason that the tail light is blinking that fast is all the "blinking power" has to go somewhere, and they all went to the back. Weird how it happens that way.
7thgensurvivor
Aug 26, 2015 06:17 PM
hoofboy
Jul 17, 2015 04:27 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
Ccoop87
Jul 9, 2015 03:26 PM
