PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. paint interior plastics
  2. Erratic Fuel Guage?
  3. Help. Problems with starting car!
  4. Do not know if this is NORMAL!
  5. Flip-Flop trunk question....
  6. Throttle Bearing
  7. Problem w/ Clearing Headlights
  8. Shift light without Tach
  9. kinda unique tach question
  10. Full HID Conversion
  11. How to Check Code for Check Engine Light
  12. DIY: Connecting your Halo/Angel eye
  13. Help with Bolt on Header!!!!
  14. Need lightbulbs
  15. does anyone know how?
  16. Question about trunk lid.
  17. Struts for hood any help.
  18. Oil Change
  19. silver housing headlights??
  20. Modifying TYC's?
  21. Valve cover difference
  22. installing kaminari side skirts and rear lip
  23. VAFC and o2 sim
  24. INtake filter
  25. Cheaper Lambo door kit?! will it work?
  26. INtake removal
  27. Clearing headlights using oven
  28. please help fast!!
  29. Clearing S2000 Headlights
  30. Custom Catback
  31. side skirt is falling off
  32. Installing Parking lights?
  33. Lambo style doors?
  34. Big updates to my DIY fog light install
  35. Burn hole in the clear plastic gauge cover
  36. Just installed a Injen RD CAI
  37. DIY Reverse Indiglo Install help
  38. How hard is it to remove gauges?
  39. HID ?'s
  40. Maint. Light came on?
  41. Taking off trim on the hood
  42. Gauge cluster lighting question.......
  43. 92 bmw corner lights?
  44. what the best strut bars?
  45. apexi auto timer
  46. Keyless Entry Won't Work
  47. ATTN: H4 HID Owners
  48. B18 in a 7th gen
  49. Cooling fan switch
  50. magna flow muffler rattles..help!
  51. Extending Intake Sensor Wire?
  52. HELP ME PLEASE!!! alarms
  53. Dripping Water Under Car????
  54. Changing Manual Transmission Fluid DIY and Micron Filter DIY ?? DIY's needed
  55. Stained glass or Vinyl?
  56. problem clearing lights. PLEASE HELP FAST!
  57. DIY side skirts
  58. A question for anybody that has dx with swapped cluster....
  59. honda gave me a datarecorder...
  60. speed limiter
  61. single windshield wiper blade???
  62. 2002 EX Interior Questions
  63. AEM intake vs V2 intake
  64. Regarding new headlights
  65. rsx-2 engine on ebay
  66. Intake, Header, Exhaust
  67. Maintence Required
  68. does anyone have pics of...
  69. Regarding new headlights
  70. Seat brackets?
  71. RXS Type S muffler fit on '01+ Civic coupe?
  72. Injen SRI DIY?
  73. Anyone know 95 Eagle Talon n/a motor code?
  74. How do you recharge filter?
  75. Gauge wiring question
  76. What kind of ATF should I use??
  77. AEM CAI & 1/2 a CAI (SRI) speculation.
  78. License Plate
  79. Grill/rad. cover help...
  80. haha RSX intake in my Civic *now w/ pic*
  81. shifting an auto :p much wear?
  82. spoon's EK civic kevlar Direct flow pipe
  83. Adjusting rear camber w/out camber it?!
  84. I DID IT, Thanks all for the advice
  85. What the best brakes pads?
  86. DIY EVO look alike
  87. Help with reverse glow gauges!
  88. need help with NOS AND V-AFC
  89. black housing lights
  90. maintenance req. light?
  91. Rear SI Brake Swap
  92. NX kit Installed and running?
  93. after intake manifold - upgrading fuel system
  94. Diff. Brands of Indiglo Gauges...
  95. Diff. year, same intake ?
  96. Help w/ Voltmeter Install
  97. Painting guage bracket?
  98. street glow UB kit, how do you install the sides?
  99. Axle nut problem (HELP!!!)
  100. Alot of questions Please help
  101. RSX intake into Civic EX?
  102. ummm... ok. i cant tell if this is a rice liar or not, but it sounds good...
  103. trunk springs
  104. Glow Kit???Any Idea???
  105. Re-Painting Trim Pieces
  106. Clearance issues?
  107. How to remove upper bolt when changing radiator coolant?
  108. muffler...
  109. diy/aem pulleys
  110. Kamikaze head/Magnaflow catback
  111. Question about painting trim pieces
  112. problem with shap turns
  113. tranny question
  114. Fog Light Install
  115. tranny help
  116. OEM foglight kit and under spoiler compatible on '03?
  117. Fox Whistle/ Alarm Siren
  118. How do you center the steering wheel?
  119. trading in my car..questions
  120. Octane sides help!
  121. Drain bolt for automatic tranny fluid (ATF) change?
  122. Draining the cooling system
  123. Need some help finding the right wire....
  124. Electrical load
  125. O2 simulater for Kamikaze header
  126. Gauge Cluster Removal...
  127. Clutch Install?
  128. Open Pod Monster Flow Air Filter
  129. Front Hub Removal????
  130. DIY: DX OWNERS, HEADS UP! POWER LOCKS!
  131. MAKE STICKY!! DIY REAL ALTEZZA UPPER GRILL
  132. my smoking AC, wft happend?
  133. trim pice ?
  134. Altezza grill question
  135. Engine Swap (RSX-s) Question...
  136. SENSOR NEAR INTAKE
  137. to all those with DIY "How To Paint Trim Pieces"
  138. cleaning out fuel tank?
  139. Wet Filter Type vs Dry Filter Type...
  140. LED BULBS ON SPOILER
  141. OEM BODY KIT QUESTION
  142. To the people who have installed Revo, OBX.....HELP!
  143. Need help on removing silencer out of exhaust! Tried everything!
  144. Gauge Needles Sticking
  145. answer
  146. alternator?
  147. Ive got a weird question
  148. DIY VTEC Light 2?...
  149. Help with Painting Trim Pieces
  150. Replacing SRI Air Filter?...
  151. splash guards 2dr = 4dr?
  152. help with header fast
  153. Mugen EK civic front lip
  154. Camshaft from d16 work on d17?
  155. odometer fraud
  156. shaving handles
  157. EMERGENCY HELP!!!!!!!!
  158. UNDERDRIVE PULLY Help!!
  159. How hard is it to retro fit Audi A6 Projectors in to Halo Projectors?
  160. 1993 MB 300e
  161. rebuilding the transaxle
  162. DIY for gas trunk shocks.. Mex's style
  163. DCsport header with my setup? Opinions needed
  164. Need info on HID's
  165. Need Help On Removing Back Seats?
  166. 2001 civic fan & radiator
  167. ANGEL EYES
  168. CAI, Hydrolock, details?
  169. INSTALLING ANGEL EYES
  170. Warranty question
  171. none vtec to vtec
  172. Piston specs?
  173. Power Windows DIY yet for the DX?
  174. Throttle Cable Adjustment Help!!!
  175. vibrant axle back~
  176. 2000 si ecu chip work on 7th gen ??
  177. Autometer A-Pillar pod
  178. Projector HID Conversion
  179. Dyi for hp header??
  180. Challenge for all DIY gurus (attn: Grey!): one-touch moonroof open/close
  181. Boring the Throttle body
  182. DIY Air/Fuel Gauge
  183. which cam?!
  184. exhaust help???
  185. Condenstaion In Halos!!!
  186. please help
  187. removing momo hub
  188. Oil Drain Plug?
  189. Is there a difference in trannys? EX, Lx, ETC..
  190. DIY: Steering Wheel "H" Color Change
  191. how to install seats
  192. DIY: Schroth Rallye 4 Harness Install
  193. Muffler sounds
  194. anyone know how to tamper with the signal bulb?
  195. Synthetic oil, revisited...
  196. front and rear strut bars
  197. Sedan Radiator OEM part#???
  198. guage cluster question?
  199. Swapping out gauge clusters?
  200. can't close carbon fiber hood all the way
  201. is the Kaminari ram air hood functional?
  202. tanabe exhaust fitting
  203. thermal with OEM rear lip?
  204. Amsoil
  205. which is more efficient?
  206. What % of civics are made in Japan?
  207. Factory Air Intake question
  208. removing center dash piece
  209. Painting Calipers?
  210. strobes, where to put them?
  211. DIY: Tanabe R-Spec Cat-back Exhaust Install
  212. 7440 - The final verdict
  213. 85 hatchback
  214. mom crystal shift knob wont stay tight
  215. DAMN SILENCER
  216. Regarding gauge cluster lights
  217. Spark Plugs
  218. slidin question
  219. another bulb question
  220. My car just scared my pants off
  221. light bulb question on stock tails
  222. 95% done debadging my car, need help
  223. VTEC LIGHT STAYS ON!!!!
  224. tightening the airfilter
  225. Opening Up Alteeza Tail Lights
  226. DIY Throttle Sensor question
  227. DIY SPOILER.. STEP BY STEP INSTRUCTIONS
  228. Someone please help with Indiglos..
  229. HELP!
  230. Who has Oil pressure guage and coolant temp?
  231. Front lip install
  232. HELP!!! 7440 Bulb install???
  233. halo projectors w/ hyperwhites?
  234. Got Racing Seats, Questions About Installation
  235. back pressure with header??
  236. Wrapping in Carbon Fiber
  237. Removing the orange piece..any advice
  238. heaDlight problem
  239. VAFC Problem
  240. tire removal
  241. how do i remove center console
  242. Seat replacement - question about wiring harnesses?
  243. H11 xenon or halogen bulb?
  244. How To Remove The Orange Piece from My Headlights
  245. Help! Need Someone to take Pics Please
  246. Adding another turn signal switch?
  247. HP headers + co2 sim
  248. Stock Bumper removal
  249. o2 simulator.........
  250. question about interior fan
