Grill/rad. cover help...
Subscribe
May 18, 2003
OK so I know this is not a "tech" issue but this seems to be the best spot for the question.
I jut got the RS grill and did not know that the radiator cover would not go back on - need to know if everyone just left it off or if there is a way to make it work.
Please get back to me quickly as my front bumper cover is off and I'd like to get it done today if possible. Thanks much.
2001 EX Coupe
SSM with clear heads(now)
Jazzy
May 18, 2003
do you got a 2dr or 4dr. If you have a 2dr your stock cover will not work. You can leave it off if you want but if you feel you need it you need to go and get the radiator cover for a 4dr civic.
May 18, 2003
you can get sedan radiator cover then you will be fine.
or you can cut coupe one with dremel tool
May 18, 2003
Since you have a Coupe, you need to buy a Sedan radiator cover. This will fix your problem.
May 18, 2003
Ok - so the sedan cover is the answer... thanks for the quick replies folks. I'll pick one up from the dealer, or ask people in the area.
Jason
Subscribe
