Gauge Needles Sticking
Old May 7, 2003
emajndat's Avatar
emajndat is an unknown quantity at this point
Has anyone had problems with their Indglow gauges catching their needles. My MPH is getting stuck. I tried to put very thin 2 sided tape behind the gauges to get them to stay, but still no luck. And ideas or anyone with the same problem? Thanks
Old May 8, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
mine did that, just give them time to reset. or maybe you need to press down on them some more to flatten them. in time they will go back to normal. mine did that when i installed my gauges.
Injen
Old May 8, 2003
Spazbitte's Avatar
Spazbitte is an unknown quantity at this point
I had that problem too when I was using to sided tape that was thick. My tach was getting stuck which we know sucks. But I switched to Stotch tape that was double sided and stuck in around the base and then flatten the gauges. Havent had the problem since. If you notice its sticking in the same spot then you need more tape there.
Old May 8, 2003
injencivic's Avatar
ya i wouldnt use double sided tape.
Injen
Old May 8, 2003
OmegaStauf's Avatar
OmegaStauf is an unknown quantity at this point
I used 2-sided tape with no problem. Use scotch like Spazbitte said.
Old May 13, 2003
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
i used rubber cement and havent had a problem with it since..
Old May 13, 2003
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
Indiglo gauges SUCK!!!!!!
Old May 13, 2003
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Ok that was really good information and help Why don't you grow up a little more and at least say that it is your opinion or give an explanation why.
Getting back to the subject. Try adding 2 sided tape like it was suggested above. It may be that the gauge is not sticking back enough.
Old May 13, 2003
GreenNVicious's Avatar
Newbie
Two sided tape, yep. They still stuck a little, but then i got pissed and just flicked the stupid needle thing in the middle and it's been great ever since.
Old May 13, 2003
emajndat's Avatar
thanks guys, ive added two sided tape but still having a problem, im going to take it all off and do it all over again
Old May 13, 2003
CivicHX01's Avatar
there is a black plastic ring (or washer) under the needles... that needs to be flat on the gauges and not in the needle... use a sewing needle or something like that to flatten it all around... that could be whats causing your needles to stick...
Old May 13, 2003
fuledya's Avatar
Super Member
I get sick of explaining my situation, just felt like giving my opinion that's all. I had the same problem, although when I took the overlays off, my tacj kept jumping around, I had ruined my cluster. Luckily I had 1 month left on my warranty and convinced the dealership they had just suddenly broke!
Every overlay I have seen for our cars is a bad design. There just isn't enough clearance between the needles to add overlays in my opinion, hence the need for tape, glue, etc. I just gave up and realized it wasn't worth the time or money. Some have had good luck, others not, I guess it's just a 50/50 with our cars. I've installed qauges on other cars, i.e. integras, neons, and they have a lot more clearance than ours.
Anyways, good luck, and bare with me and my frustration.
Old May 14, 2003
that sucks, but ive done them on a WRX and they have like no clearance at all man... if a wrx can be done, i think a civic can be done too.... "Dont get mad get glad"
Old May 15, 2003
gotti's Avatar
I dont even have any tape under mine and they're fine. They only get a little stuck for like 2 seconds around 80, but its all good
Old May 15, 2003
nsiegel5's Avatar
nsiegel5 is an unknown quantity at this point
If you are real careful you can give the needle a little tug to raise it off the new gauges but dont pull too far otherwise it will pop off then your fk'ed! But that is the best way because it will never stick again just go slow and dont pull too far!
Old Jul 8, 2003
fine02civicgurl's Avatar
*BoY*CaR* *GiRL*DRivER*
fine02civicgurl is an unknown quantity at this point
i have the same problem- but i cant "visibly see" where my needles are sticking! it jumps until i get up to 45 mph, then it does right... guess i need to pat it down or something...
Old Jul 8, 2003
cryption's Avatar
2003 Nissan Frontier
yeah i have that problem too ... mine gets stuck at 78 but it wont go past ... no matter what. I don't even have any tape holding them, they stay in place nicely, but the damn thing gets stuck and i dunno what to do about it. Keep this thread going so we can find a fix cuz i sure as hell hate knowing im goin 100 but seeing 78.
Old Jul 9, 2003
i read on some other threads (maybe even this one), that they need time to settle. once they settled, that worked for some people. but some took out the gauges and put tape EVERYWHERE and that works. its just mph needle, prolly cuz its in the "middle" of the gauges, and the middle prolly tends to bulge out...
Old Jul 9, 2003
cryption's Avatar
i've had mine about 6 months and they never 'settled'
Old Jul 9, 2003
NismoSpecV's Avatar
NismoSpecV is an unknown quantity at this point
I have reverse indiglo gauges in my car and they were sticking. Try taking some very fine sand paper and sand the inside part of the needle. This will help it glide better along the gauge face even if it isn't taped down good enough. I haven't had a problem in like 5 or 6 months after doing it.
Mike
Old Jul 9, 2003
KaOtIcCiViC's Avatar
KaOtIcCiViC is an unknown quantity at this point
I had the same problem with my gauge needles. I saw that the needle had to be angled. What I did was press down on the "pointy" part of the needle to the gauge face and then just tap it up and see if it glides good or not. I don't know if that'll help or not.
Old Jul 9, 2003
cryption's Avatar
mine glides just fine it looks like everywhere tho ... like the needle doesnt look close to touching the face of the guages at all
Old Jul 10, 2003
NismoSpecV's Avatar
It may look like it is gliding fine but one little bump will set the whole needle off. I just made sure the gauges were pressed down really tight and the underside of the needle was sanded. The needle hasn't given me any problems (except when I rev fast in 2nd gear).
I was so frustrated after I got them on and they kept sticking. Also make sure they are lined up with the hole for the needle. One of mine wasn't and when the needle was turning it was catching the side of the gauge which made the needle stop working. Hope this helps some.
Mike
Old Jul 18, 2003
emajndat's Avatar
Does anyone know if our needles can come off with the tool? Some other cars just come right off using this tool. That might make our problem easier to fix as we can just put a hell load of tape on the backs of them without worrying on busting the needle off
Old Jul 18, 2003
tbone2k2's Avatar
tbone2k2 is an unknown quantity at this point
i have to agree indiglo gages do suck. they look cool and everything,but they screwed up my needles. i had to replace the whole guage cluster. 160$ wasted.
Old Jul 18, 2003
evol's Avatar
evol is an unknown quantity at this point
I took mine off, the trick to setting it back to factory is pulling the pin that stops it from dropping all they way, and when you re-install the pin act as if your are setting it at true zero, re-install the pin and let the needle fall back against it. and you should be go to go .
oh and I used scotch 2 sided tape and never ever had probs with the needles
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
