UNDERDRIVE PULLY Help!!
Old May 5, 2003
Bolemite24's Avatar
Bolemite24 is an unknown quantity at this point
Hey has anyone put on an underdrive pully? What is the best way to approch it? How did you like it ?
Old May 5, 2003
Meatman's Avatar
Meatman is an unknown quantity at this point
I'm in the process or putting one on. I cant get the darn bolt off tho. I put 125 ft/lbs of torque to it and the sucker didn't come off. I talked to my neighbor that used to build sand buggy's and he said that its probably got more then that anyways..... Now I need to find out who has a compressor w/ like 200psi so I can get the thing off.
I ordered the manual for the civic's and It should be here anytime. I cant wait to find the torgue spec on that bolt.
Old May 5, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
you might want to try puting penatrating oil on it, then using a wrench or socket with a long piece of pipe on the end
Old May 5, 2003
Bolemite24's Avatar
What gear do you have it in my friend had the same problem in his Subaru and He had to have it in Fith gear and it just came right off try that
Old May 5, 2003
RoadRunner's Avatar
huh ???
Old May 5, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
It shouldn't matter what gear your in. Like bickford05 said try some WD40, let it soak in and then try with a socket and put a pipe at the end to extend the handle to give you extra leverage.
Old May 8, 2003
spookini's Avatar
spookini is an unknown quantity at this point
I read somewhere recently that if the bolt is stuck, try heating it w/ a propane torch (can get one in hardware store of HDepot for $20), then immediately hit it w/ your socket or a air gun...it should come off. Also, be sure your'e turning it the right direction!
Old May 8, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i wouldnt do that...heating the bolt can weaken it...that could be bad news...i am planning on installing an underdrive pulley next week using my uncles big *** impact (600ftlbs in reverse) i'm sure it will break it loose
Old May 8, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
screwdriving in the flywheel, works great and no expensive tools.
Old May 8, 2003
spookini's Avatar
No, the thread I was reading the guy was talking about just a few seconds of heat, not long extended heat.
If anyone is interested in how much of a bitch getting the bolt off can be, read this thread, it's friggin scary...:
http://pub143.ezboard.com/fhondadser...cID=2374.topic
Old Mar 8, 2004
ziggyboo84's Avatar
ziggyboo84 is an unknown quantity at this point
put some WD40 and let is sit for 5 min. damn wd40 works on everything i took half of my old eclipse engine apart wiht wd40 any screw that seems a little hard rusty or dirty just spray it on and let it sit for aobut 5 min it comes off believe me!
Bounddyy
19
Jul 20, 2015 02:42 PM
PwN3d
Jan 7, 2003 09:41 PM
SaiyanMatador
Sep 12, 2002 02:58 PM
Black99Vtec
Jul 14, 2002 05:09 PM
EternalVTEC
Jun 29, 2002 06:49 PM
