Seat replacement - question about wiring harnesses?
Old Apr 24, 2003
opto_isolator's Avatar
I have taken my passenger seat out before and noticed that I had to disconnect two wiring harnesses underneath the seat. I believe one is for the seat belt, the other, I'm not sure about. I don't have side airbags, just the two front ones. Anyone have any ideas? I want to make sure that I won't have a problem if I put new seats in.....
Old Apr 24, 2003
CarbonFly's Avatar
Both of those harnesses run to the seatbelt buckle. I think one is sensing if the seatbelt is buckled and the other is a sensor in the long tube of the buckle section that senses when to lock the seatbelt like when you get into and accident and the belt stops.
I replaced my seats with Tenzo's and haven't had a problem with them.
Old Apr 24, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Originally posted by FlyRiceRacer02
I replaced my seats with Tenzo's and haven't had a problem with them. [/B]
You got your seatbelts yet?
Injen
Old Apr 24, 2003
RedDragon333's Avatar
you shoulnt have a problem, connect all the wires for the sensors up right and your on your way, may i suggest TenzoRalley seats from www.cdm-motorsports.com
talk tto Chris McBride you can get two Seats, sliders, brackets, CF sills, shoulderpads, all for under 500 shipped
both me, flyriceracer and several others have bought from this guy, well worth the money
Old Apr 24, 2003
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
nothing wont happen, i replaced my seats w/ oem black seats... the only thing that will happen is the SRS light will stay on. you could just have the dealership reset it for you for $60+
Old Apr 24, 2003
CarbonFly's Avatar
The SRS light will NOT stay on. unless you have side airbags.
Old Apr 25, 2003
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
wrong, i dont have side air bags in my car, and the light was still on...i think the trick is NOT to start the car with those sensors unplugged. if you do then the light will come on, and STAY on. it's an easy DIY to do yourself if you do start the car, or if the light is on, just need a paper clip, and some patience. look in the diy section under electrical if you need help resetting the srs light!
Old Apr 25, 2003
CarbonFly's Avatar
WRONG, I don't have Side Air bags in my car, and the light NEVER came on. Why on earth would you start your car in the middle of a seat swap?
Old Apr 25, 2003
errrr not start the car, but if you put the key in the ignitioni and turn it to the 2nd position (I.E. to listen to the radio while u work) then ugh the light still stay on because at that stage the sensor sees that something is wrong resulting in the SRS light to stay on.....
so bottom line it doesnt have to do if you have side air bags or not, it has to do with if you turn the car on or the the 2nd position in the ignition....get it?
Old Apr 25, 2003
CarbonFly's Avatar
Well if you don't have side airbags and you don't turn on your car during the swap then you will get no SRS Light.
If you don't have side airbags and you do turn on your car during the swap then you will get the SRS Light.
If you do have side airbags, NO MATTER WHAT, you SRS Light will come on because there is no place to put the extra 3rd plug.
Old Apr 26, 2003
Ok
I think that the seat belts are an "integral" part of the SRS system (ie, if your seat belts aren't working, than the SRS light will come on).
In any case - I see that the seat belts are part of the seat. What happens when I replace the seat? Can I still use the stock seat belt buckles or what??
Old Apr 26, 2003
XxSoVeReiGNxX's Avatar
i saw a guy in a benz pull onto the emergency shoulder, get out his ride and rip out his seat belt, a few weeks back. the automated motor must have malfunctioned and thought he was not there, thus trying to retract itself while tightening on the driver.
Old Apr 26, 2003
CarbonFly's Avatar
Re: Ok
Dude, I HAVE replaced my seats with aftermarket racing seats. I have been telling you the whole time that everything will be fine. The brackets for the seats are made so that the buckle can be attached to it.
Here are pics of my racing seats.......
Old Apr 26, 2003
I know...
That you have stated that they work before fly, but the problem is - I tend to have bad luck with such endevours, which is why I want to make sure before jumping in! I appreciate all your help with this. I'm probably going to call that guy that you mentioned above (when I get some cash!).
Old Apr 26, 2003
NeonImpact's Avatar
Forum Sponsor
he's the best way to go!
Old Apr 26, 2003
nightkids1's Avatar
Initial D!!!!
how much lower are those seats compared to the stock ones?? i plan on getting seats soon
Old Apr 26, 2003
CarbonFly's Avatar
They sit about 2 inches lower than stock.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Jon-Ohio
Jun 30, 2018 08:10 PM
nicholaai
Apr 27, 2015 05:54 PM
Importracer
Nov 26, 2001 10:39 PM
