Big updates to my DIY fog light install
Old May 21, 2003
Bellz's Avatar
I put a lot of time yesterday into adding some useful info to the DIY.
Check it out here and let me know what you think. Most of what I've added is at the bottom after the last set of pictures.
I've added a FAQ about the install. If anyone can come up with more questions for it, post them here or email them to me and I'll add them.
Old May 21, 2003
NeonImpact's Avatar
Forum Sponsor
i think it looks good man..
when i get mine, im sure ill be using your DIY
good job
Old May 21, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
looks good...now i need to get some foglights!
Old May 21, 2003
importz2k1's Avatar
Awesome DIY man!!
Very easy to follow.
Old May 21, 2003
CarbonFly's Avatar
LOL, my name is credited in your DIY.......cool. Good job on the fogs!!
Old May 22, 2003
Weaponx12o's Avatar
good job! kinda makes me want to get fog lights now hehe
Old May 22, 2003
Obsidian's Avatar
Obsidian is an unknown quantity at this point
Hey Bellz,
I used your DIY to install my fogs and they were great. I think you might want to add a few things. After doing some research, I found that there isn't another grommet to use on the driver side to route the cable. So if you wanted to install the switch next to the cruise switch, you would need to extend the cable.
Also, the screws that came with my set from tornactive were not self tapping. I had to drill holes into the plastic to screw in my lights.
Also, in terms of leaving the 2x1 inch plastic for the garnish. I see that you've cut around it. That isn't necessary. You can just leave that bottom 3x1 inch piece uncut.
The fastest way to get the harness into the interior through the grommet is to cut off the connectior. push a string from the inside cabin through the grommet into the engine bay. Tie and tape the string to the cable. Snake it back through. Reconnect the connector. My grommet was completely sealed so if you were to try to cut a hole big enough for the connector to go through, it will take a while.
those were my observations. Hope that helps others.
-Obs
Old May 22, 2003
XxSoVeReiGNxX's Avatar
geez I could have saved myself $50 in installation&labor if you did this a year ago. But I trust my shop, they installed my 12 disc changer, my alarm, and since then my fog lights. If anything should go wrong, they take full responsibility. yay!
gj on the diy !
Old May 22, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
Props on the DIY! Very well done. Now, when I can afford it, I gotta get some fogs from Rob. Nicely done. With your DIY the should be kept to a minimum.
Old May 22, 2003
Fletchman04's Avatar
Fletchman04 is on a distinguished road
fog lights here i come!!! woo woo!! looks really good...peace!
Exterior
Nov 28, 2025 05:23 PM
bsmiley
Apr 27, 2015 01:27 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
disaster
Nov 7, 2001 05:30 PM
