removing center dash piece
Old Apr 28, 2003
EnProceso's Avatar
i want to take out my middle vents and i was reading the DIY on how to do it. so would i need to unhook my stero or anything or could i be able to take them out and just leave it in?
Old Apr 29, 2003
robbclark1's Avatar
Retired suspension supermod.
U know there is a DIY section, right? It is in there
http://www.7thgencivic.com/modules.p...howpage&pid=50
Old Apr 29, 2003
Connie's Avatar
It is a little scketchy but from reading it I would say that the radio comes out with the dash, but I would not know from experience...and he said he read it Rob, lighten up a little
Old Apr 29, 2003
XxSoVeReiGNxX's Avatar
you'd have to take off the cigarette lighter panel, and unscrew two bolts screwed in a metal bar from inside there. then you could pull out the whole top radio/center console (still a hard thing to do, just be careful). I don't think you would need to unhook any of the electronics, but it would be easier if you had the front of the console resting on a seat or surfacen, and have the back facing up wards towards you. then look at what's there. You only have to do some pulling from that point on.
Old Apr 29, 2003
CarbonFly's Avatar
Originally posted by XxSoVeReiGNxX
you'd have to take off the cigarette lighter panel, and unscrew two bolts screwed in a metal bar from inside there. then you could pull out the hole top part (stylle a hard thing to do, just be careful). I don't think you would need to unhook any of the electronics, but it would be easier if you had the front of the console resting on a seat or surfacen, and have the back facing up wards towards you. then look at what's there. You only have to do some pulling from that point on.
No you don't. When I take mine out I just take a flathead and pry at the edges of the console and it just pops right out. Then I unplug everything on the back and i'm good to go.
Old Apr 29, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if you follow the DIY for replacing the HU, the vents come out with that, its all one big piece. Once you pull that piece out, your going to want to remove all the connections for the ventilation controls and the hazzard flashers, it gives you more room to work with. i found the best tool to get that center piece out is a panel popper
Old Apr 29, 2003
isn't there a silver plate on the center console that is screwed onto another silver plate that is connect to the dashboard?
you mean you don't have to take these bolts off?
Old Apr 29, 2003
CarbonFly's Avatar
Nope, not on mine. I've removed my dash 4 or 5 times now.
Old Apr 29, 2003
damn I got hosed. That right bolt's hard to reach too. Only had to take it out once.
Old Apr 29, 2003
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
dude i dont think the 2002's come with those bolts just the 2001s and its a biotch...
Old Apr 29, 2003
Mbow's Avatar
I have those bolts in my '02.
I wouldn't pry out the center console from the outside. That is almost a sure fire way to mar the dash.
Take off the power outlet piece and stick your hand up through there and feel for the back of the center piece. Then push outward on it and it will pop the center out an inch. You can easily get your fingers under and pop it the rest of the way out. I have seen some marred dashes in the member's rides section in the past.
Old Apr 29, 2003
robbclark1's Avatar
you're right. sorry. my bad.
Old Apr 29, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
Those bolts hold in the Factory Radio so if you have an aftermarket radio installed you wont have to worry about the bolts i think.
Old Apr 30, 2003
the 2 bolts secure the whole radio cage to the rest of the car, you can still put the bolts back in with an aftermarket HU
Old Apr 30, 2003
yup!
Old Apr 30, 2003
Mox's Avatar
Mox
Mox is an unknown quantity at this point
I have always had to take the bolts out in order to get my center console out. Like was said before, if you try to pry from the outside, you are chancing messing up your trim. Just undo the two bolts, reach up inside and push it out from behind the radio.
IB Jose
Site News
Jun 2, 2015 12:58 PM
dariusld
May 29, 2015 12:44 PM
HuDaThaN
Dec 9, 2001 07:21 PM
Foom
Dec 6, 2001 01:11 PM
CivicHX01
Nov 2, 2001 08:49 PM
