Ive got a weird question
Old May 6, 2003
cdmx's Avatar
What if i were to install an intercooler before the intake filter on an intake?
does the intercooler restrict airflow or does it just make it denser and flows just the same....I dunno why but I was just wondering this...What Would happen if i got a small intercooler and hooked it on somehow to the intake?
Old May 6, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
Not positive, but i think it would be restrictive going through a intercooler and a intake. And it probably wouldn't do much anyways. The reason for an intercooler on a turbo is cause those turbos get very hot, and that heat is blown to the intake manifold. Intercooler just helps cool things down a bit.
Old May 6, 2003
cdmx's Avatar
I understand...so it really only works with the turbo cause of the high pressure
Old May 6, 2003
tdiddy's Avatar
Well it could work if you had a front mount intercooler and put the filter somewhere under the driver side headlamp. But they do have intakes with a front mount air filter( not sure for our cars). But if you were to try it, intercoolers are kind of pricy. Probably be wiser to just save up for the whole turbo kit.
Old May 7, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
The hot air from a turbo comes from air compression. The air you are using from an intake, CAI or SRI, is not even hot enough for the IC to make any difference at all. I don't think it would be noticeably restrictive. Most have pretty high flow rates.
Old May 7, 2003
tdiddy's Avatar
True, thats why i said i wasn't positive
Old May 7, 2003
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
if thought of doing this too, but would end up being kind of pointless till i decided if and when i get a turbo.
Old May 7, 2003
cdmx's Avatar
Yea i thought so...I knew it wouldn't work like someone would think...but I got the idea from someone who said to mount an intercooler under the kamanari hood scoop to get any functionality out of it. But i guess that really wouldn't do sh|t either
Old May 8, 2003
prototype's Avatar
x-factor
Old May 8, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i wouldnt advise doing that, i dont think it would be good on your car not having the complete turbo kit.
Injen
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
civic98?
Aug 13, 2015 01:32 AM
BootyDo
Jul 26, 2015 10:38 AM
1khilari
Jul 9, 2015 08:12 PM
