please help
Old May 1, 2003
corruptnu2's Avatar
corruptnu2 is an unknown quantity at this point
please help
I dont understand where u are supposed to go through the firewall in our cars to run the power wire for the amp. I looked at the diy picture and i found that circle with the velcrow and i tried to drill a hole trough it but there is metal on the other side. Beside that there is wires that are coming through a hole but when i stuck a coat hanger it didnt come out in the engine bay please help me out with this
Old May 1, 2003
THEANTIRICEST's Avatar
Premium Member & 1 Millionth Poster!
THEANTIRICEST has disabled reputation
try PMing a mod from the Tech Stuff forum
Old May 1, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Peel back the carpet in the passenger footwell, you will see this...
That wad of wires runs into the engine bay.... tightly tape the wire you want to run through there to a hangar, and run it through the hole. You might have to push a little. I actually found it easier to go under the car in the engine bay... The other side of that rubber boot has a "nipple" on it. Cut the nipple off and shove the hangar through it and pull it into the car. Either way works.
