PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. need someone to help me out with this
  2. uncapping exhaust
  3. What messes up a car?
  4. Air intake Tempature?
  5. Anyone have experience information reguardiing body paint?
  6. ATF change more often...
  7. Penzoil Fuel Injection Cleaner = 100km more
  8. A few questions about changing coolant?
  9. Aem Cai Trouble!!!!
  10. side molding
  11. complete a/c system???
  12. DIY: Rear Brake(Shoe) adjustment(tightening)
  13. Updated FINISHED Attempting return fuel conversion soon(pics inside)
  14. relocating cruise control question
  15. Key duplication?
  16. How to change power steering fluid?
  17. Cooler Air?
  18. Another SRS Light RESET ?
  19. Question about Automatic Transmission Fluid Change?
  20. quick ? about relocating my battery
  21. Rattling noise in tire
  22. Advice needed on Exhaust Mod for EX Auto
  23. V-AFC II vs. VENOM 400 HELP!!!
  24. anybody car without their cat
  25. lower console (w/ cigarette lighter) removal for ipod install... help?
  26. Whats the speed sensor's pulse number?
  27. Lowering Automatic Shift Rod?
  28. Rattling/Popping noise under the car
  29. angel eye headlights
  30. Hyper Voltage System v.s. Ground Kits
  31. autoshift knob doesn't move
  32. Paint job
  33. engine error with de cat hi flow
  34. GSR Seats
  35. What the different?
  36. my check engine light does not come on. anyone know how to fix it? is the light out?
  37. Is there a replacement knob for auto shifters?
  38. Hardwiring Radar Detector... And best place to position it.
  39. Help on what to get
  40. stock cam gear noises?
  41. Any Perform Diff btw Universal & Model Specific Muffler?
  42. Final Reduction Gear Ratio change
  43. how to remove the automatic shift knob?
  44. 15K or 50K
  45. Revo SS Install Info.
  46. Thanks Opto isolator !
  47. HELP! Need to pop front bumper
  48. Need help with strut bars
  49. tapping RPM signal wire in gauge cluster...
  50. throttle cable
  51. Vtec
  52. halo ring problem...
  53. 3rd brake light
  54. NGK Iridium Part number?ASAP
  55. Is there a recall for the door locks? Anyone know the steps to remove door actuator?
  56. bodykit's tape is loosening.
  57. D17Y8 Hybrid Motor
  58. vtec apex afc settings
  59. repainting costs for shaved trunk
  60. Drilled a hole through my gas tank.
  61. How can i quiet my exhuast down for a short period of time?
  62. Front Door Courtesy Lights
  63. 03 Center Console Removal - Need Some Clearification
  64. AEM v2 intake FILTER!!
  65. Seat question
  66. coupe OEM headlights in a sedan
  67. removing bottom rear seats ??
  68. Catalitic Convertor is Toast. What are my options?
  69. Adjusting sensitivity on alarm???
  70. Will RSX type s leather seats fit in ours?
  71. Frankenstein K20/K24 story in SCC mag
  72. k24b??
  73. Help-- Clanking noise from gears... I think
  74. Lx with v-tec
  75. Can't believe this about K&N
  76. How do i fix this suspention problem!?
  77. How to run wires inside the AC vents?
  78. tach testing green wire...
  79. Catback Exhaust Install Help
  80. Question about eletrical issue
  81. Rsx Instrument Cluster In 02 Civic
  82. SRS light is on... and won't turn off after audio system installed...
  83. help with cai
  84. Ordering 04 Tails from Majestic
  85. S-AFC II or V-AFC II for 03 Civic?
  86. Relocate moonroof / sunroof switch?
  87. strange intake sound help
  88. help...m3 mirror install wiring question
  89. Question about Torque Wrench?
  90. Need Rallye Red paint
  91. Apexi RSM question (help please)
  92. Radiator/ ATF flush
  93. What's the difference?
  94. RSX Console Into Civic
  95. CAI or ram
  96. o2 sensor (pics inside!)
  97. ex exhaust into dx model
  98. air filter
  99. i need some help
  100. copression test numbers
  101. quick Q and A about paintjobs
  102. Repair Manual Civic 04 LX
  103. k&n fipk
  104. Intake Air Filter?
  105. What should new tranny fluid feel like?
  106. performance axles?
  107. EP3 seats into an EM2?
  108. heat sheilds...
  109. EX -> DX header?
  110. 100K What needs to be done?
  111. What is this bar?
  112. blow off valve making a rattle sound in between shifts
  113. Will bondo stick to plastic?
  114. problems with my 98 ranger
  115. Mini-me swap...
  116. Cat. Converter Gone??
  117. Ecu
  118. '00 oil filter size in '01 civic
  119. emblem shaving tragedy
  120. NEED HELP ASAp!!! Cam gear bolt!
  121. help with rough idle!
  122. i got my denso today !
  123. My stupid alarm. Please help me quick.
  124. How Can you change the Gear Ratios........
  125. srs light is on
  126. Full A Pillar Gauge Pod....
  127. oem side skirt problems
  128. Cruise control install
  129. will AEM make a fuel rail ??
  130. tail lights
  131. ECL goes off after changing Spark Plugs
  132. Auto to Manual Conversion
  133. wrong tint????
  134. AMSOIL FILTER - Question!
  135. Engine cuts out between 3900 & 4000 RPM
  136. Power Steering fluid
  137. too many miles
  138. Auto Tranny Fluid
  139. Cone filter cleaning/oiling
  140. Turbo kits
  141. Removing airbag sticker on front of visor...
  142. Cruising in second gear?
  143. will this fit my lx auto?
  144. Increasing intake sound?
  145. Where is the odometer reading saved?
  146. gauge cluster ?
  147. Heavy engine mods - what size injectors to use?
  148. autometer volt gauge...
  149. clean AEM filter?
  150. Emblem Help
  151. Major Ecu Problem
  152. Major Cat-back problem
  153. Engine Wear?
  154. For those with service manuals
  155. VAFC Problem
  156. Aem Sri
  157. o2 sensor
  158. Need help with HKS exhaust.
  159. better gas mph on highway
  160. Which spot in engine bay has cooler air?
  161. AC Condenser for a 2004 Honda Civic LX
  162. Side Airbag Sensors Question, please help ASAP
  163. Problems with belt noise
  164. Low Fuel Light. Not working
  165. HP gains from AEM V2 on '02 LX
  166. 10k mile oil change
  167. Push button starter
  168. 04 Civic Intake Question
  169. Will a B16B fit in my 03 LX
  170. gauge test mode?
  171. Racing Timing Belt
  172. Rattling from rear wheel
  173. any one with a full gauge pod pillar in their car?
  174. Adding velocity to intake ?
  175. allen wrench problem
  176. Help installing volt gauge
  177. Integra dead (attn: mechanics)
  178. Parts List
  179. '04 coupe front "H"
  180. Need Help on RS Style Grill DIY
  181. Tranny re-build
  182. Is TCI a good company?
  183. K&N FIPKII question
  184. Gauges in AC knobs?
  185. Underneath carpet?
  186. Any good products to insulate metal intakes?
  187. New sound I hear after intake?
  188. Clearing Tail Light????
  189. How to hook up wire to constant 12v line
  190. DIY: Passenger Door Lock Switch
  191. My airfilter box wont come off?
  192. How do I reset the ecu?
  193. Anyone have the DIY for clearing headlights?
  194. Cost to install kit, already painted?
  195. valve cover bolts
  196. 2002 civic LX mods
  197. what WHP? what 1/4 mile time?
  198. RSX shift boot: Will it fit??
  199. VTEC Activating time??
  200. non7thgen--> acura lenged/NSX airbox?
  201. my car died..
  202. Booty Call With Alarm Help
  203. Nimrod mechanic told me this about 5W20
  204. My ultimate intake hose!
  205. stripped bolt, need help ASAP!
  206. cotter pin removal and upgrade kit
  207. installing an OBX header on 2001 LX w/out a catalytic converter
  208. Front Spring Problem
  209. Torque specs for calipers???
  210. What am I to do Now!?
  211. How much can I deck my cylinder head?
  212. de cat pipes
  213. how to change Stock Headlights?
  214. 1% too fast or 2% too slow?? What would you prefer?
  215. fog light install??
  216. Rear bumper clip
  217. Greddy Blue Box?
  218. 35000 kms what should be changed?
  219. Help: Oil Change Question
  220. Manual Tranny Fluid change on an 02 civic ex. What tools are needed?
  221. 2001 Civic 1.5 VTEC, Auto Trans
  222. installing header, hi-flow cat, and cat-back...
  223. Engine Problem
  224. Just Installed Revo Short Shifter!
  225. Synthetic oil and VTEC engagement issues?
  226. DIY: manual shift boot on A/T
  227. Fuse Problem ?
  228. RETRY: Door panel DIY fabric
  229. 150 hp please
  230. Removing Sedan Bumper
  231. Buzzing/humming sound
  232. Drive Shaft Seperated
  233. Magnaflow exhaust hitting frame
  234. Transmission Help
  235. oil change
  236. Driver's Power Lock Broken...Again!!
  237. Grille Inserts
  238. Transmission Help
  239. Cold cathode angel eyes
  240. this is the funniest thing ive ever done...
  241. Hid Wiring Expert Help Only!!! HELP ASAP!!!
  242. Window tinting...
  243. Draining Tranny Fluid?
  244. Ww G5
  245. Removing Rear Seat Cushion?
  246. Why dont our cars have a WOT A/C cutoff?
  247. Autometer Oil Pressure
  248. Adding SRS Seats to a non-SRS seats civic..
  249. Clearin the headlights and smoking the tails!
  250. Ecu Programming
