Help: Oil Change Question
Old May 19, 2004
Ershall's Avatar
Ershall is an unknown quantity at this point
I just changed my oil. I have never filled the filter up before I put it on, I always just pour a bit on the top to lubricate the rubber gasket and screw that f*cker on. My brother just scolded me for not doing so saying that the filter won't work if I don't fill it up with oil....Is he right? Do I really have to drain the bish again, fill the filter and full it up again? Or is that not neccesary like I have always thought.
Old May 19, 2004
flotsamm's Avatar
No your bro is wrong.. you'll be fine. Adding oil to the filter before screwing it on is a good thing to do since it wont have that air to displace when you start your engine up, but its not necessary. The first couple of seconds your engine starts the oil pressure is forced into the filter so I wouldnt worry about it.
But you should lube the rubber seal with a thin coat of oil to help seal it and make it easier to remove. But it should be fine.
Old May 19, 2004
Ershall's Avatar
^^lubed the seal...thanks man
Mods, please lock this
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
mrohitredd
May 28, 2015 10:03 AM
BootyDo
May 7, 2015 04:46 PM
Grazzhopper
Nov 11, 2001 08:06 AM
