Synthetic oil and VTEC engagement issues?
Old May 18, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
I did some research and sqw that there have been some complaints that the synthetic oil properties will sometimes effect the oil pressure and its viscosity properties will not allow VTEC to engage properly. Does anyone have any experience with this? i have been using it since 2000 miles and I have 4500 on it now. Im tempted to go back to dino oil since VTEC seems to be pretty touchy when it comes to oil pressures and levels.
Old May 19, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
i dont know the way vtec works fully, but since its rpm based.. i dont see why oil pressure would have any affects, since there are so many variables that can change oil pressure. just seems to me like a sensor monitoring rpm would report to the ecu and then activate the vtec solenoid at a set rpm, which really wouldnt have anything to do with the lubrication system. i could be wrong though
well, forget my reply, i was thinking of my 00si i use to own, which was rpm based. now everything is variable so you could be right
Old May 19, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
i-vtec isnt rpm based its oil pressure and like 3 other things. so i could see the viscosity messing with it but ive never heard of n e thing like it.
Old May 19, 2004
ctx66's Avatar
^^ yup, completely my mistake, i was thinkin of the old vtec system
Old May 19, 2004
robbclark1's Avatar
Retired suspension supermod.
Where did you hear this? Synthetic oil is fine. Just choose a good viscosity.
Old May 20, 2004
CivicHX01's Avatar
yea, whats your source? and its 5w-20 or 30 that you should use...
Old May 20, 2004
robbclark1's Avatar
You can use anything that isn't too thick or too thin. Run thinner in the summer if you live in changing climate. 0w-30, 5w-30, 5w-20, 10w-30, etc. Somewhere around there.
RIPSAW
Nov 6, 2015 04:36 AM
normaspirated
Apr 26, 2002 03:04 PM
Jimmy24
19
Feb 19, 2002 12:59 PM
01LX
Feb 7, 2002 06:37 PM
roundeyericegirl
Canada West
30
Jan 20, 2002 04:17 PM
