Where is the odometer reading saved?
Old May 31, 2004
xylamic's Avatar
xylamic is an unknown quantity at this point
Question Where is the odometer reading saved?
I was wondering if anyone knows where the odometer reading is saved and if anyone has changed it? (I know there has to be someone) I know this a legal issue, so PM is you don't want to answer on the forum.
I have looked throughout the gauge cluster and i don't see any sort of battery, this leads me to believe it's in the ECU....anyone know?
Old May 31, 2004
hi2nr's Avatar
hi2nr is an unknown quantity at this point
ooooo i know this one......its in ur guage cluster....that holds all the mileage..its not in the ecu...i changed my 04 dx cluster to a ex cluster a few months ago and the miles were set back to 000000 cause its a new cluster, but anyways its in the guage cluster...if u change it out u need to put on a sticker displaying the original miles on the car before the swap.
Old May 31, 2004
hi2nr's Avatar
it dont need a battery in the cluster either its like a playstation memory card dont need a battery to hold memory! If ur planning to disable the odometer u need to find that wire that reads mph but then u cant read ur mph wen moving.
Old May 31, 2004
xylamic's Avatar
i figured it would've been like the cmos in a computer, but thanks a lot! i'll pick a new wholesale cluster.....
Old May 31, 2004
xylamic's Avatar
how much did you pay for yours? or do you know what the retail price is? i'll get like 40% off of that.....
Old May 31, 2004
Well here is the story. The displayed cluster miles are stored in the gauge cluster. So if you swap to a new one, it will be zero miles. However, the ecu still keeps a record of the actual miles on the car. So the real mileage can always be obtained by tapping into the ecu. There are some speed shops that are actually able to "flash" the new cluster with your original miles this way.
Old May 31, 2004
xylamic's Avatar
I have heard of people that go to honda because they screw up their needles in their cluster and honda just replaces the cluster and puts a sticker with the mileage on the door. If it was possible to "flash" the cluster, wouldn't honda be doing this instead of just stickers?
Old May 31, 2004
Honda is lazy and cheap. It costs them money and time to send out the cluster to a shop. But it can be done. Dealers will just give you a sticker on the door frame saying mileage was reset on a certain date. That's bad to have if you ever sell the car.
Now I've taken my entire cluster apart many times. I even swapped parts from a second cluster I got off ebay to fix stuff I've broken. Is there a reason you're wanting a new one? What specifically broke on the one you have now? Or do you have a DX and you're wanting an EX cluster for the tach?
Old May 31, 2004
luciferi's Avatar
luciferi is an unknown quantity at this point
I know one Acura and one Honda Service manager very well and they both say mileage is not stored in the ecu.Then again if no one ever showed them, they would not know. I know when I hooked up the Honda tester, you do have to input the milelage and vin before you can obtain codes. If you know of a way to flash from Honda equipment, I have access to the Honda equipment. I want to add miles to my ex cluster
As far as sending it out, the places online charge more than a cluster at retail. Some seem to be a flash and other are adding their own chip in like playstation modchip.
Old May 31, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
what ??? i posted a thread about this and he said the mileage was stored in the ecu !! damn it !
http://www.7thgencivic.com/forums/sh...d.php?t=157175
Old Jun 1, 2004
xylamic's Avatar
Civryder02: Yea, i saw your post earlier when I was looking for this question. I've gotten mixed responses. All I've learned for a fact though is that the cluster stores the displayed mileage.
Luciferi: Thanks a lot for the info.
Old Jun 1, 2004
Civryder02's Avatar
geez .... at least now i know the real answer thou
Old Jun 1, 2004
Havok2k1's Avatar
Wicked Pissah Admin
So you decided to start a new thread with the same question instead of posting there?
Old Jun 1, 2004
xylamic's Avatar
So does anyone know for a fact that the mileage is stored in the ecu also or not?
Old Jun 1, 2004
hi2nr's Avatar
some cars are in the ecu but honda's are all in the cluster
Old Jun 1, 2004
hi2nr's Avatar
and one more thing its all in the cluster so some spedo shops are able to flash the mileage over but it will cost u around a 100 bucks to get it done......i rather put a sticker on it and say it had xxxxxxxxmiles on b4 the swap.
Old Jun 1, 2004
xylamic's Avatar
Thank you very much man!
Old Jun 1, 2004
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
Mileage is stored in the cluster and in the cars ecu. The mileage will not reset to whatever the cars mileage is if the cluster is swapped. The miles will stay with the cluster.
I changed my "silver" ex cluster with a black cluster not too long ago. I like the black face much better.
Old Jun 1, 2004
luciferi's Avatar
After a little research today, i found out the 03 up accord, TSX, and 04 TL can be flashed through the HDS(fancy Honda computer). It was unclear where the new information comes from, it sounded like it was retained somewhere in the vehicle. No one at the dealer knows, they are still trying to figure it out themselves. Whether this will be able to work on older cars without the can and ban busses is unknown.
Old Jun 2, 2004
Woodster's Avatar
Woodster is an unknown quantity at this point
Im going to be ordering a used Si cluster off of ebay, and i never plan on selling this car, basically i plan on running it until it dies, so i dont know if ill take my new cluster to honda or whatever.
Old Aug 16, 2004
ebencosme's Avatar
ebencosme has a little shameless behaviour in the past
i had a TV on my car and got stolen so when i turn the lights i smell something burning but did not know what it was (didn't mind) so took i the car to the shop got it fixed so when i got it back i turn the light on see that i don't have no ilumination so what i did was took the car to the dealer to check it out they told me some wire was doing ground on the dash but they were stupid cuz they already burned the new one they got for me and it had the same miles i had on the car so what i did i bought one on ebay but 2001 my car is 2002 i (different color) so i took everything out of the burned clusted and put it on the used like the guages even the display for the miles cuz it had another color it came out good know it matches the other lights
Old Aug 17, 2004
518's Avatar
518
518 is on a distinguished road
If mileage is stored in the ECU,
errr, I'll save my thoughts and experiences.
bottom line, it's stored in the cluster.
mjdiaz89
Jun 21, 2016 09:26 PM
Strycker
Aug 2, 2015 08:40 PM
alxz310
Jul 30, 2015 12:18 PM
NoobyKid
Jul 18, 2015 02:01 PM
General 7th Gen
Jul 9, 2015 10:17 PM
