copression test numbers
Old Jun 9, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
I looked all day and searched and want to know if anybody knows what the copression numbers should be. I need them for an EX. I think I remember somewhere around 147 but not sure. thanks
Old Jun 9, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
Don't know on the H, but that sounds low. Whatever the number, they should all be within a few percent of each other...
Old Jun 9, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Here you go. Alway check the source - www.Honda.com
http://www.hondacars.com/models/spec...me=Civic+Coupe
Old Jun 9, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
uhh.. he means in psi.. what the standard compression is. not the compression ratio.
Old Jun 9, 2004
SMX's Avatar
SMX
Yep, I mean psi too. Most motors I've checked are in the 160 to 185 range. 145 sounded low. However, I work mostly on older cars.
If he were talking about compression ratio, 145 would be on the high side...
Old Jun 9, 2004
CrewChief's Avatar
SMX he was talking about the standerd post punking civic. everybody always says ratio. I am looking for PSI. I know the lx is 135 to 140 but what is it for an EX. I need to do a compression test and a piston bleed down check. Think I have blow from one of my piston rings or valve guide seals.
Old Jun 10, 2004
ponyman's Avatar
ponyman is on a distinguished road
well unless all of your pistons had the same misfortune then you can just check the psi for all of the cylinders, it's not like there are a bunch, and if you have one that is way off of the rest then you have a problem, otherwise you are A-OK!
Old Jun 10, 2004
SMX's Avatar
SMX
If you're looking for ring and seal problems, just do the compression test and look for deviations. Don't sweat the predicted number.
Do the compression test dry first then squirt a little oil into the cylinder, turn it over a couple times and do it again. If you get different readings wet and dry, you have ring problems. If you have one cylinder that is off wet and dry, it's something at the top of the cylinder (seals).
Old Jun 10, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
(opens manual)
Let's see.... at 200 rpm with wide open throttle: Minimum 135psi. (EX)
Maximum variation 28psi.
I'd say you are in the sweet spot.
(closes manual)
Old Jun 10, 2004
SMX's Avatar
SMX
Touche'
alxz310
Jul 30, 2015 12:18 PM
Jul 12, 2015 11:54 AM
Ccoop87
Jul 9, 2015 03:26 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
