- primary o2 sensor fell off?
- GSR Blades and Wheel Spacers...
- Another Crazy thought popped into my head. Looking for feedback.
- Wireing Diagram!!!!!
- 01 hx header swap
- Did i mess up my Ground Wire DIY
- How to take off rear lip???
- Steering Wheel Noise
- stock 1/4
- Tap Splices for side marker!!
- Changing oil...
- Got a Newb Question
- miss shift
- WTF?! Energy suspension REAR motor mount WON'T FIT - Blame Honda!
- Our cars run rich from the factory right?
- Neuspeed Strut Bar
- Gear Ratio
- factory head unit removal 02 civic lx
- a word of caution removing power sterring belt.
- Engine trouble.......
- Engine Sttutering.........
- Does anyone know how to prep bodykit??
- Lx Whp---ex Whp
- Dual Exhaust Question?
- LEDS burnt out in brake light.... what to do??
- CarChip OBDII data logger?
- painting rims
- Quick defrost light question
- Side marker pics????
- Backlit gauge ??
- Alternators ?
- Malfunction Light/ engine cutoff
- Turbo Timer?
- full tank
- how hard to rethread oil pan?
- Help! Ex mirrors on Lx
- clearing headlight diy Q
- headlight plasma questions
- Wow, EX final drive = 4.411, LX=4.111 - big difference!
- HELP ANYONE!!!!!!!!!>>>>>>>
- bigger injectors.
- Just installed reverse indiglo gauges. need help
- Steering Wheel Lock
- Clearing Headlamps?
- The best way to remove paint (touch-up paint)???
- need help
- Engine miss
- Well, I removed my PS belt too and...
- exhaust shake..
- Headers for 2003 Civic LX ????
- How much oil?
- Removing belts to reduce drag..
- Initial impressions after removing power steering not bad at all
- VAFC II Tunned people
- Intake Silencer
- Tein S-Tech Spring Questions
- Altezza Grill
- I-Vtec for dummies
- SRS light with aftermarket seats ????
- Fiberglass??
- help installing oil gauge... and boost gauge
- Short throw
- 5th gear keep slipping help
- have a question help!
- less weight and simple clean JDM look...???
- check engine light?
- need honda p73 ecu pinout
- Don't be Angry With Me
- Rev Limiter....
- 04 coupe grill on an 02 coupe?
- Rims size (bolt pattern)?
- Wht do some post like in here get locked??
- just bein stupid.....
- screwed with auto??
- Air Intake / RPM questions!
- shift light
- b&m shifter install issues?
- need help!!! car not starting
- 04 carbon fiber lip and jdm sides
- honda warranty
- short shifter
- Timing Belt? What if it Breaks??
- DIY: Tightening E-Brake
- DIY black
- Should a car with 13k miles need an alignment?
- Tools needed for header install ? ? ? HELP
- malfunction indicator light
- intake silencer
- How do you burn rubber w/ a auto trans
- o2 sim. install HELP
- Xenon low beam only problem
- Newby wants advice!
- Would driving w/out PS belt cause any damage?
- Undo Battery Or Not
- supercharged AUTO????
- Gas pedal poping noise after installing Sportlines
- your exhaust: bolted or welded?
- gutted OEM cat (ex)
- Diy: Remove Stock Front/rear Bumpers
- RSX seats
- HX --> EX tranny swap details
- Got my ingalls camber kit....
- Fog Lights help
- aftermarket resonators
- Better Aerodynamics!
- Oil Leak
- RS VS SI ... and intake question???? ASAP
- how do you install HID's?
- Noob kind of question.......
- Mind Of A Car Theft
- Strut and spring removal
- Spoiler Question
- Help with HALO's
- Esuperchargers, wow what is this about any ideas?
- How Exaclty Does One Delete The Sunroof?
- How to install a/f gauge the right way?
- Need help from someone with a HELMS*URGENT*
- EXHAUST that sounds OEM
- Im Deperate
- Throttle Body Heater ByPass
- Chrome Trim Painting
- gauges
- Got my new exhaust
- Replacing clutch after 30,000 miles.....nice!
- Headlights
- ECU Jumper
- top dead center, how do i find it? tdc?
- coming back to stock & other Qs
- Grounding Kit wiring
- SRS reset ?
- need help with cigarrette lighter removal
- Are 01 seats compatible with an 02
- Center Conole Lights
- Take this CHECK THIS OUT BMPer
- Timing Belt Question?
- Halo Headlight Projector alignment
- sound
- 1st gear possible?
- short shifter
- removing trim on trunk?
- what relay for kill switch?
- Computer Issue
- Has anyone tried OBIT ECU?
- DIY Valve Adjustment *EASY* Stop the Clicking
- VAFC II what are your gains youve gotten?
- Ecu Help
- front bumper removal
- CREAK SOUND PROBLEM FROM LOWERING 03 Civic
- Alarm system with extra channels?
- fuel milage
- Sloppy, Sluggish Shifting
- DX Shifting
- Site to Print out Recall for rocking chair
- Explosives straped to the Seat.
- How do I remove this piece (pic)
- Hi-milage cars. Who's got 100k miles +
- Trunk popper relay wiring
- lagging on oil change improve gas mileage
- Are CAI's really worth getting?
- SRS lights
- whats our ECU code
- ecu...professional help please
- D17 performance intake mani
- Will d16 headers fit a d17?
- Auto Shifting?
- How to disable the SRS system / light
- Hyper Blinker Help?
- V-AFC II vs V-AFC
- Dont have a gas cap hanger? Alternate solution
- head bolt tourque specifications
- plastic intake mani
- The Roar Of the 7th Gen???/
- 04 fit an 03
- ?'s about custom intake manifold install
- DIY needed for Angle eye hookup.
- Cleaning cone intakes.
- DC headers, how good are they?
- burning smell
- clutch problems
- For those of you with Alarms
- DX instrument panel
- Where to buy momo HUB for 2002 Civic DX? Also with questions.
- Cruise control 01 dx
- weird noise - a/c related
- wires under the front seats
- Changing the color of the lights
- AEM replica short ram
- SPC Front bolt question
- no clue
- wiring BMW 3 series side markers
- SOHC Non-Vtec Engine Work worth it?
- Jet Performance V-Force?
- Headers on an lx?
- Port n Polish Exhuast Manifold
- Fuel amount when EMPTY light comes on...
- hmmm NA?
- How do i get [paint off plastic light ?
- Is downshifting bad?
- door poppers on lambo doors
- Want an SI Repair Manual?
- another hood question
- Subframe HELP
- Intake Manifolds
- Help with dome lights...
- black out headlights 04 coupe
- Help w/ emanage
- Hood question?
- Fiberglass reinforced bondo.
- apexi-safc?!?
- Got my S&B filter..guess what the tech told me when i called?
- OBD-II <-> PC Interface! ***FINISHED!***
- Need help fixing a pulley/belt related prob
- body kits, drops, etc...
- what to do first??
- diy cleared headlight question
- Wiring help, very technical
- DIY: Reset SRS light - '02 Civic???
- LX to EX exhaust conversion
- Couple questions about installing M3 mirrors.
- Clutch Question
- 95 prelude hot/cool switch problems
- radiator drain plug
- What hapenned if I take out the Catalyst?
- The lower... the more noisier.
- keyless entry
- diagnose
- anyone know how to intall a starter motor?
- question
- Odometer Help
- How vtec works....
- fuel return help!!!
- Factory Security System Question.
- Parts # for shift boot
- VAFC II works well
- VTEC / ECU wire gauge?
- No wheel well gaurds into engine bay???
- Installing Sparco seats
- Removing AC?
- power steering fluid foaming out
- 800 dollars to spend, But on What?
- leather boot for auto tranny
- Just wondering...............
- Change autometer gauage color
- individual throttle bodies
- RSX-S Shift Boot
- Starting to like 04 headlights!!!
- Engine Noise... manifold???
